The eManage Magic Setting for Timing Control...
Old Jul 25, 2003 | 08:38 PM
  #131
SuzukaS2K's Avatar
btw: thanks Wes for the dip switch correction on my e-manage!
Old Jul 25, 2003 | 08:55 PM
  #132
Wesmaster's Avatar
Originally posted by SuzukaS2K
...if I need to pull more timing out how much farther I could go?
There is no harm in retarding the timing more, if you feel the car needs it then do it.
Old Jul 25, 2003 | 10:28 PM
  #133
terry@spool's Avatar
You should pull out way more than that....You should pull out until you hear no detnation. You can pull out as much as 12 degrees if needed. To much retard will raise egt's and to little will have detonation
Old Jul 26, 2003 | 05:11 AM
  #134
SuzukaS2K's Avatar
ok........I'm going to pull some more timing out today and I will let you guys know the result.
Old Jul 26, 2003 | 06:27 AM
  #135
Reignman's Avatar
Hey SuzukaS2K,
How are you detecting the detonation and pinging? Are you just hearing it or do you have some kind of monitor to detect it?
Old Jul 26, 2003 | 06:32 AM
  #136
SuzukaS2K's Avatar
Originally posted by Reignman
Hey SuzukaS2K,
I can hear the detonation b4.......I wish I have a monitor for it tho.
Old Jul 26, 2003 | 06:35 AM
  #137
Reignman's Avatar
What exactly does detonation and pinging sound like? Is it hard to hear it when you reving high?
Old Jul 26, 2003 | 06:58 AM
  #138
SC-SUZUKA's Avatar
Can anyone answer this question for me?
" Seeing now that the E-manage can add/remove fuel, and also retard and advance timing in our cars, this will be the ideal set-up for Nitrous S2000's. Am I wrong? Also, it should also help out a lot for the N/A S2000's also."
Chris C.
Old Jul 26, 2003 | 08:42 AM
  #139
beroznikmal's Avatar
Chris,
instead of just retarding your timing cant you do both decrease timing and also at the same time add fuel.... this way you wont have to retard that much........
Old Jul 26, 2003 | 09:02 AM
  #140
SC-SUZUKA's Avatar
beroznikmal, that is what I want to know. If you can do both add fuel and retard timing at the same time, than some serious HP will come out from a {NO2} S2000.
Chris C.
