Emanage ultimate & Timing?
Old Aug 31, 2008 | 01:47 PM
Artisan7471's Avatar
Thumbs up Emanage ultimate & Timing?
Ive been tuning on my car using a emanage ultimate, however it does not read timing, properly. You have to read timing with an obd scanner and then figure out how much to subtract or add using the emu, its a pain in the ass . My question is this, does any body have a map of the stock timing for an ap1? I figure that if I have a stock timing map it will make adjusting timing much easier. Right now Im running 10 Psi, and pulling about 4 to 6 degrees at full load and 8-9000 rpm. Stock timing is at 24 or 25 degrees at redline.
Thanks.
Old Aug 31, 2008 | 02:10 PM
MugenRioS2k's Avatar
I am using version 2.16 and i have no problem reading actual IGN timing from the stock ECU.
check your version
Now if I am pulling timing I must subtract my deg pulled from what is being log in the ULT to get the actual timing.
Chonda
Jun 19, 2014 12:21 PM
GreeceS13
Sep 26, 2013 08:37 AM
stack
Mar 28, 2009 05:20 AM
Shftat9k
Nov 8, 2007 11:39 AM
slipper
Sep 12, 2007 11:38 PM
