EMS logging question
Old Feb 8, 2008 | 07:18 AM
CourageOO7's Avatar
Chair,
What do you mean it won't log? You know it won't exactly replicate the home screen and play it back for you, right? It will simply log the values of the parameters and allow you to open it in the logger application and view graphs of what happen (you specify the parameters from the first 2 menus).
Old Feb 8, 2008 | 07:24 AM
yiannakos's Avatar
Originally Posted by Soul Coughing,Feb 5 2008, 04:03 PM
1. How do I log boost?
Boost will be explained as Kpa, you can change to Psi if you want, by going to options and changing the units!
hello guys
i did that and it now says PSIg and it has a weird reading.
something like -10,.... or something , while i was expecting to see numbers like 0 to 15.
is there a way to correct this ?
what is that g that appeared next to PSI?
Old Feb 8, 2008 | 07:31 AM
chairmnofthboard's Avatar
Originally Posted by CourageOO7,Feb 8 2008, 08:18 AM
Chair,
when I try to log the home screen, it says something like "no info to log".
The home screen is the one that has the fake tach, speedo, a/f, etc right? No actual graphs.
Old Feb 8, 2008 | 07:33 AM
Soul Coughing's Avatar
Originally Posted by yiannakos,Feb 8 2008, 11:24 AM
hello guys
you have vacuum too, which with PSIg (the actual unit name) so it will see vacuum as a - ! you should see a zero or close to it... that is where there is positive pressure in the intake manifold.
Old Feb 8, 2008 | 07:43 AM
This is the home screen that I'm using. Is this the correct screen?
Old Feb 8, 2008 | 07:46 AM
minitoyota's Avatar
doesn't matter what screen is shown as long as the car is running it should be able to log.
Old Feb 8, 2008 | 07:52 AM
And there's the problem. it will only log whatever screen is on. and it wont log the home screen.
Old Feb 8, 2008 | 08:04 AM
CourageOO7's Avatar
Yes, the AEM EMS will only log whatever screen you are on. I am going to head out and test my logger on the home screen. I want to make sure I'm not crazy.
I will post tonight.
Best,
J
Old Sep 8, 2010 | 01:16 AM
MB's Avatar
MB
Member
I know this is old, but did you get anywhere??
I tried logging last night on the home screen, and after a few mins logging I saved it. When I went ot open it in AEM Log, it said there was no data.
The rpm / speed and afr aren't moving on my home page, but all the values on the right hand side of the screen are working.
Help appreciated!
JspecVtec
Jul 27, 2015 11:14 PM
riceball777
Sep 26, 2011 05:27 AM
rsmatti
Mar 29, 2011 07:23 AM
AirborneS2K
Jun 16, 2007 01:26 PM
jakub2000
Jul 19, 2005 02:53 AM
