Engine build for 10-12 lbs on S/C?
Old Dec 17, 2007 | 06:55 PM
  #31
chairmnofthboard's Avatar
Originally Posted by John_Z,Dec 17 2007, 07:36 PM
Indeed I am.
You're running 14 PSI on stock compression??? I thought you had a head gasket?
  #32
Sideways's Avatar
Originally Posted by John_Z,Dec 17 2007, 08:36 PM
Indeed I am.
I have one of those.
Old Dec 17, 2007 | 06:56 PM
  #33
Originally Posted by 05TurboS2k,Dec 17 2007, 07:15 PM
ultra rich tune?.... i heard 10.8 was like insane
hmm I thought i was in the end of the safe zone at 7.75psi.
hmm that makes me wanna go to 10psi then...and run like 14 on 110 leaded
SC and turbo boost is different. I think 9-10psi is max for turbo.
Old Dec 17, 2007 | 07:02 PM
  #34
John_Z's Avatar
I do have a head gasket...the stock head gasket
Old Dec 17, 2007 | 07:08 PM
  #35
daaaaaaaaaamn 14 psi on stock compression. makes me feel safe at 12.5
Old Dec 17, 2007 | 07:09 PM
  #36
ATOice's Avatar
I will be using a head gasket and going to 3 inch pulley with some bolt and stud changes. no other head work till I can afford it.
Old Dec 17, 2007 | 08:52 PM
  #37
TRBOKEV's Avatar
I got a pulley I think you could use. PM me and maybe we can trade.
Old Dec 17, 2007 | 08:53 PM
  #38
TRBOKEV's Avatar
Indeed I am.
John your car is a beast!
Old Dec 18, 2007 | 10:36 AM
  #39
05TurboS2k's Avatar
Phil-
I sent ya a PM a while back asking about compression ratios mentioning 2mm I thought, you must have answered then disregarding that part since you don't run it.
or...... I'm just simply dead wrong ....which has never happened
Old Dec 18, 2007 | 10:38 AM
  #40
05TurboS2k's Avatar
.....turbo can't run equivalent boost?
Why might this be?
I'd think the tune could be done to match....and the air would be just as cold? Trying to think what the problem would be.
what's the issue? anyone?
I'd love to kick my boost from 7.5psi up to 12-13psi
