Engine dyno testing with temperatures
Old Aug 17, 2011 | 10:56 AM
YuriArts's Avatar
Default Engine dyno testing with temperatures
Hi guys,
last year I bought the IP intake and finally we're tuning the engine.
We installed egt sensors on all 4 exhaust outputs and running the car at 2500
rpm. What we see is a 10% difference in temperature betweem number1/2 and 3/4.
So for instance 1 and 2 are 500 degrees C and 3 and 4 are 550.
Does anyone know what the flow characteristics are of the IP intake? Is this
normal? We're a bit conserned. Will it level out at higher rpm and boost?
Pfab twin scroll manifold
Bosch 2000cc injectors (replaced the 1600 since engine damage from them in february)
AEM EMS Series 2
InlinePro intake manifold
Setup
@1500 rpm
@2500 rpm
Old Aug 17, 2011 | 12:10 PM
YuriArts's Avatar
Some more pics of the setup
Old Aug 17, 2011 | 01:18 PM
siadam's Avatar
3 and 4 are known to be the hot cylinders. We have had quite a few discussions on this over the years, and even one of the past 2 weeks.
Simply by design, 4 is going to get the least amount of air, and will tend to run leaner, while cylinder 3 is sandwiched between 2 and 4 and runs hot.
Old Aug 17, 2011 | 04:09 PM
Dan1987's Avatar
I use FlashPro so I am not familiar with AEM EMS, can't you adjust individual cylinder fueling trims? If so take fuel away from the cylinders that are running cooler and add fuel to the cylinders that are running hotter untill all cylinders are roughly at the average of the current temperature spread..that way your overall AFR will remain as it is at present.
(obviously if you can't do this with EMS ignore what I said.)
Dan
Old Aug 17, 2011 | 05:03 PM
hybridsol's Avatar
Off thread question- no cylinder pressure sensor with this setup? I would love to see how it changes BMEP with timing/boost pressure in the F20. Ever been done?
Old Aug 17, 2011 | 11:35 PM
YuriArts's Avatar
Have you got a link to these discussions?
Originally Posted by RealStreet
If the injectors are equal and the intake isn't any worse than stock it will be fine. It's normal to have a bit of a spread until it's loaded up. If you poke around on the web enough you will find some good reading on tuning individual cylinders. Just keep in mind EGT's get cooler with timing and you can burn one up riding the curve down.
Thanks
Jay Meagher
The injectors are equal.
Dan
Yeah we're going to tune the cilinders seperately but we found it very strange that even at these levels there is such a significant difference.
Obviously it's also alot of work.
How do others do this, almost nobody installs 4 egt sensors so most tuners are working with 1 temperature?
Old Aug 18, 2011 | 04:31 AM
sohc_mshue's Avatar
Thanks
Jay Meagher
Dan
If you want to tune individual fuel for each cylinder I highly suggest using a 4 channel wideband setup instead. AEM sells one now.
Old Aug 18, 2011 | 04:45 AM
wadzii's Avatar
Banned
get it loaded up and do a few lower boost pulls and see what you see.
from what i have seen, they do run differently, but not enough to do the work to "fix"
Old Aug 18, 2011 | 06:20 AM
siadam's Avatar
Don't all motors though have different variations like this.
Ring seal, intake/exhaust manifold design, head design, differences in injectors, no matter how small all play a role in the outcome in each cylinder, especially when you compare 4/6/8/+ cylinder motors.
Old Aug 18, 2011 | 06:55 AM
wadzii's Avatar
Banned
thats correct.
