Engine let go on dyno
I learned from my past experience with the motor blowing on my s2000 is to only take my car to someone who specializes in that car, and to make sure they look over everything before tuning.
There's a lot of people out their that claim to be tuners that have no idea what they are doing. There's a lot of things that can go wrong and if they don't specialize in that car they might not catch it.
The clock also strikes 12 at least once in the day, but usually 2 times lol. I’ve run that kit too and would never rely on it for a long term daily set up where its function was the single thing between my motor surviving or not surviving. But yes, im a large proponent of water/meth injection - just the right one for the application. That AEM kit is inadequate in multiple ways. If you were using it for anything more then cooling your AIT, you were simply testing fate. For a few runs of drag racing a month, for a "couple years" (30 miles? anything goes, until it doesn’t) Not a system you want to rely on to make added power in your street car. As I said, there are much more consistent, better/safer delivery systems/configs to use for power support application.
Ultimately, imo, if you want 500whp+ to run around on, you'd be dumb to just use pump gas. Get something with more cylinders to handle the load, and you can make 600whp on pump all day. Is race gas cheap? Of course not, but neither is a new motor. As others said, the more you push the limit, the smaller that safety window becomes. My opinion is better to play on the safe side, should you get some bad gas or something acts up, you won't be needing a new block.
Originally Posted by boostedf22c' timestamp='1426664231' post='23544529
Back in 08-09 we ran a simple off the shelf AEM single nozzle water/meth 50/50 system and pump gas. Made 700whp and the car ran 9.9@141.
Ran that system for 2 years with no issues.
FWIW.
FWIW.
Originally Posted by The Machine' timestamp='1426480558' post='23541418
A car with forged internals should be more than capable of handeling 400-500whp reliably on pump gas in combination with a tuner who knows what he's doing.
I'm looking for around 450 reliable horses too next week using the Vortech v2 and the 3.8" pulley, plus the rest in my sig.
Going to who I hope to be an expert, Granite State Dyno in NH.
I hear it's all about that bass (no, I mean tune and fuel delivery).
Supercharged and turbocharged are 2 totally different things. A 450whp Supercharger will always be "safer" on pump gas than a 450whp turbo charge car. The reason behind that is that the supercharge car doesn't make full boost until redline while a turbo car makes full boost around 4500-6000rpm depending on the setup.
that's just my personal opinion though.
either way, just put some E85 in there and make 500whp on a stock motor no problem.
While I agree that over 500 is a stretch for pump, I don't agree that over 400 is. There have been countless cars on this forum alone that were tuned over 400 on pump 91-93 and are still running strong.
Like stated, there isn't enough information to 100% point fingers here but, you have 3 competent tuners who aren't happy with the fuel map posted. That says something.
Everything comes down to the experience and confidence of your tuner. They will let you know what they believe is the limit that is within their "safe zone" based on your entire setup. The better the tuner, the more aware of this limit. Even a poor tuner can make a great deal of power for a short period of time.
