Engine let go on dyno
Over 400 especially supercharged is nothing at all for this engine. I've been over 400whp for 50k miles miles(193k miles total) and going strong. Just last year added meth but before that it was 93 pump only.
Did you deal with/get to the bottom of your oil consumption issue that developed recently?
And you chimed in as if you knew exactly what we had on the car. The failsafes we didn't have in place and how we didn't put any time on it. And basically discredited what we did with the kit and how it's inferior in every way.
I'm not debating this.
Originally Posted by Moddiction' timestamp='1426769327' post='23546248
I love the aem meth kit. Works great, faisafe setup works perfect as well. If any error, ecu dumps fuel and pulls tons of timing instantly. Great kit!
Oil consumption seems to have gone down. Not sure why. I still do burn some but I'm not even worried about it anymore. A lot let smoke out the exhaust now as well since running the meth. Less gas is being used so I guess a bunch of it was from the tune being conservative up top.
I am running a dual port catch can that is vented now which seemed to help some with the consumption. I do still burn oil but I haven't noticed nearly as much oil smell idling or anything. (Havent driven it since November though except a 5 minute around the block drive)
[/quote]
Now I think your the one assuming here
[/quote]
[/quote]
You can connect it to ecu (I think nitrous port) and then any time that light is triggered you can setup the failsafe with the ecu. That is how mine is setup. I also have an electronic check valve installed right before the nozzle which helps prevent any water/meth from being dumped into there and puddling.
The aem failsafe gauge is pretty bad ass.. you can use the 0-5v output from the failsafe gauge to modify the boost target. Set up your meth kit to come on however you want, once the gauge see's flow it will send that to the EMS, then as the flow increases you can also increase boost. Flow drops, so does boost. No map switching or hard cuts or anything like that.. Just a switch to turn on the meth kit
Carey is at the top of the food chain with this chassis/engine...I think it's kind of disrespectful to question the tidbits of knowledge he's droppin' with assumptive forum babble.
Single Nozzle Meth Kits were working WAY before anyone even had full control of their ECUs. Are there 'theoretically' better ways to chop the onion? Maybe...but a single meth nozzle def works.
