Engine let go on dyno
Old Feb 19, 2016 | 04:53 PM
  #81
Spoolin's Avatar
Originally Posted by VitViper
I'm happy the OP found his way to me and we were able to help him get his car sorted. Stock block w/ ID1700 on a PTE Gen2 6262 on an AEM V2 Flex Fuel setup now. I stopped just shy of 500whp (stock AP1 baselines 190-ish here) on 92 octane pump gas, but it felt like the setup had 520-530 in it on pump gas, however I didn't really want to push it since we were doing a flex setup.
We got the E content up to 76% using the pump gas E85 (tests 82%) just down the road from the shop. The 3 port interrupt boost control solenoid setup was maxed out at 21psi, but the power was still fantastic -- 700hp with a Gen2 6262 isn't anything to sneeze at.
Good numbers right there but you can make more power than that safely with the 6262. I had the JB 6262 and made 741 whp and 471 lbft at 29.6 psi on the stock block and e85. We never got around to dynoing it again but did up the boost to 34 psi and suspect we were around 800+ whp with it.
Old Feb 19, 2016 | 07:08 PM
  #82
TixonPB's Avatar
We wanted to push it to mid 700s, but I only had a 7lb spring in the gate, so the 3-port solenoid would only let us make 21psi, so we were forced to stop there. We wanted to step it up for sure, but we were held back.
Old Feb 19, 2016 | 07:39 PM
  #83
VitViper's Avatar
Originally Posted by TixonPB
Originally Posted by Spoolin' timestamp='1455933236' post='23885616
[quote name='VitViper' timestamp='1455848544' post='23884706']
[/quote]
Oh yeah, I was down to go for more, can only do so much with a 3 port in interrupt mode. It's a solid setup and fast with "only" 700.
S2K-F8
Sep 22, 2011 06:57 AM
alanpikku
Jul 1, 2011 08:46 PM
2big4aS2000
Jan 24, 2008 08:37 AM
WhiteAP1
Aug 8, 2007 12:53 AM
