Engine running hotter than normal
Old Apr 19, 2018 | 11:27 AM
  #21
calerouxz's Avatar
Originally Posted by s2000Junky
See if you can find an identifier like the gpm on the existing pump, or serial number.
The pump is a Jabsco 59500-0012, 15 LPM (3 GPM) I find the GPM conversion odd though, should be 4 GPM going from 15 LPM, but it appears to be discontinued, replaced by the 59510-0012, 12.5 LPM (3.3 GPM), and while it would seem it would work, I'm worried about mounting, as it has an odd shape, and my current clamp probably won't work for it, but it appears as it ships with a mounting bracket.
Old Apr 19, 2018 | 11:36 AM
  #22
s2000Junky's Avatar
My clamp broke right out of the box so I had top fabricate something on the fly to mount. If your a decent back yard mechanic its not hard, and if all else fails, zip ties Plenty of things to attach to under there.
Old Apr 19, 2018 | 11:41 AM
  #23
calerouxz's Avatar
I can work with that then . Just order that one then?
Old Apr 19, 2018 | 12:23 PM
  #24
s2000Junky's Avatar
Yes sounds like a good option based on the info you provided.
Old Apr 20, 2018 | 11:04 AM
  #25
calerouxz's Avatar
Update (SOLVED!!!): I was finally able to test all the wires and connections that go to the pump, turns out the port the wire from the relay goes into was dead, we also saw that the relay was busted and just put in a new one. I will hold off on buying a new pump, but will definitely get it flushed and get new fluid into the aftercooler. We just changed to another port.
Thanks S2000Junky for all the help!!!
Old Apr 20, 2018 | 11:07 AM
  #26
s2000Junky's Avatar
S2000_FUN
Mar 16, 2011 12:34 PM
Boost76
Aug 6, 2010 07:43 PM
wingnutLP
Oct 22, 2007 10:15 AM
medicalstudent
Mar 1, 2005 07:51 PM
S2K_Spain
Feb 26, 2001 02:36 PM
