Engine Torque Damper
Old May 1, 2018 | 04:19 AM
  #21
Pinky's Avatar
Originally Posted by hecash
My S2000s have been supercharged since February of 2001 (Comptech Kit Serial #0003). I have over 170,000 supercharged miles on an S2000 platform. My cars have had thousands of track laps laid upon them. I've never had a motor mount problem with the OEM equipment.
I am an '00 over 150K miles on them and motor mounts are just fine. This makes me how people keep blowing up their motor mounts!
Old May 2, 2018 | 10:50 AM
  #22
AllMotorAP2's Avatar
Curious on how much torque your supercharged S2000's are making?
Old May 2, 2018 | 11:23 AM
  #23
Mijae007's Avatar
I dont think engine torque has anything to do with how an ETD functions. The word torque is used interchangeably but does not have the same meaning. It simply reduces any vibration, movement, or torque created by the motor in relation to the chassis. In doing so, i'd imagine this will help prolong the life of motor mounts by drastically reducing the stresses put on the mounts.
Old May 2, 2018 | 10:59 PM
  #24
RolanTHUNDER's Avatar
In the case of an ETD, torque means engine movement which is a direct result of the torque it produces while running. The damper dampens that movement much like the shocks dampen your springs movement. You are right, it would ease the load on the motor mounts prolonging their life in the long run. I'd like to get the M&M Honda ETD as it comes with a pre cut hole in the aluminium heat shield for the damper to fit through saving you cutting your stock shield.
Old May 14, 2018 | 10:12 AM
  #25
azian6er's Avatar
Originally Posted by echofilter
Just want to stop in and say i have a KW c38-91 installed with the Ingalls ETD. There is no interference in the bracket. It can be a little bit of a bitch getting the ETD bracket onto the block, but nothing interferes and according to billman is the only ETD he'd recommend using with the KW kit
Same here. However, if you want to put the kraftwerks belt cover on, then you need to cut off a small portion of it for clearance with the ETD. This is what I did, and it is working great.
Old May 14, 2018 | 10:13 AM
  #26
azian6er's Avatar
Just had mine dyno'd - 308@ the wheels on a dynojet
s2k_jay
Jan 31, 2018 01:17 PM
yorkies2k
Aug 9, 2016 12:14 AM
ian05s2k
Jun 29, 2013 11:22 AM
EvasiveMotorsports
Feb 23, 2009 03:23 PM
s2konroids
Feb 10, 2009 06:50 AM
