Enough for E85?
Old May 20, 2011 | 12:58 PM
Redline S2K's Avatar
Default Enough for E85?
I have the following for my fuel system, but I'm not sure if it's enough to run E85.
DW300 fuel pump
FIC 900 (1000cc) injectors
Should I get a rail and FPR, and maybe larger injectors? Do I need to upgrade the stock lines?
Old May 20, 2011 | 03:34 PM
passmans2kny's Avatar
how much power are u trying to make?
Old May 20, 2011 | 03:46 PM
I want to make 550-600 on E85. If I make over 500 I'll be happy.
Old May 20, 2011 | 04:46 PM
my guess is u could make around 550 on e85 before u max out ur injectors or ur fuel pump
Old May 21, 2011 | 05:46 AM
s2000442's Avatar
You are going to need bigger injectors if you do not raise your base fuel pressure. I started to run out of fuel with one aeromotive pump on 1600 ID's at 544whp at 18psi E85. You can get close to 500whp on your current setup. You dont need a rail and your stock lines are fine for that power level.
Old May 21, 2011 | 06:10 AM
Can you put a FPR on the stock rail? Looks line I'm gonna need bigger injectors at the least.
Old May 21, 2011 | 06:44 AM
DFWs2k's Avatar
You can use the aem fpr w stock rail.
Jaspah
Feb 4, 2017 12:12 PM
UH-60DRIVER
Apr 4, 2016 10:58 AM
riceball777
Sep 21, 2011 10:00 AM
TerminatioN
Jun 10, 2011 05:06 AM
JohnnyP912
Nov 28, 2009 12:59 PM
