FI+4.57+Clucth/flywheel package launching
Hey Guys,
I might be going to the track soon and needed some advise with the new set up.
Can anyone with FI+4.57+Clucth/flywheel package or a similar set up let me know what rpms you are launching at as well as recommended tire pressure?
Also, about what times should i expect to run in the 1/4? You can see my mods in my sig. I consider myself to be a decent driver and quick shifter.
Thanks.
Thanks.
Whatever RPM you feel comfortable dropping the clutch at. I personally leave off idle for the 2.20 60 ft time, and no broken parts.
Sidestep the clutch a 7k will get better 60ft times, and more broken pieces. You still have OEM axles and transmission gears.
Having the rear suspension lower than stock also weakens the inner CV joints as they don't riide all the way inside the housings.
s2kpearlwhite
Aug 12, 2008 03:33 AM
JBETANC
Apr 29, 2003 06:41 PM
