Finally finished my Afi turbo install
Old Oct 28, 2012 | 05:39 AM
  #31
timg's Avatar
Looks like they didn't get penetration and it started cracking at the joint before jumping to the HAZ. Good luck!
Tim
Old Oct 30, 2012 | 12:35 PM
  #32
jordannn93's Avatar
I'm just going to get it welded locally.
Old Nov 2, 2012 | 09:30 AM
  #33
4forall's Avatar
Honestly i wouldnt bother reusing that old piece. From the looks of it the metal has begun to break down already. Even if you weld it back up, the weld will be the strongest point and it will break again right next to the weld. I would try to get a new flange and get it welded on.
Old Nov 2, 2012 | 09:43 AM
  #34
jordannn93's Avatar
Already got it welded. Came out great. If it breaks again I will get a new piece.
Old Nov 3, 2012 | 09:14 AM
  #35
TerminatioN's Avatar
Definitely keep an eye on it.
I wouldn't expect it to last long... but you never know, maybe it will hold up.
Old Nov 3, 2012 | 09:37 AM
  #36
jordannn93's Avatar
What would make it last long ?
Old Nov 21, 2012 | 07:57 AM
  #37
jordannn93's Avatar
Got my waste gate fixed for free under warranty by tial. I went to have my tune adjusted yesterday. It was set at 13psi. Last night I did a 4th gear pull and it hit 20 psi at around 7500. What can be the issue? It was fine on the dyno the boost maybe creeped to 15 in higher gears.
Old Nov 21, 2012 | 08:13 AM
  #38
jordannn93's Avatar
Car is on pump 93
http://s771.beta.photobucket.com/use...F0EA5.mp4.html
Old Nov 21, 2012 | 08:42 AM
  #39
liquidgsr's Avatar
How much boost?
Old Nov 21, 2012 | 01:16 PM
  #40
jordannn93's Avatar
13 psi.
I just hooked up my t1r 70r exhaust today it's so quiet. Maybe almost stock exhaust quiet
