Finally got the car on a dyno...
Old Oct 19, 2005 | 10:59 AM
  #111
EssTooKayTD's Avatar
Is everyone having this problem also running Emanage? Has anyone switched to AEM EMS and had their problems go away?
Old Oct 19, 2005 | 01:53 PM
  #112
S2000_Europe's Avatar
I have AEM EMS
Old Oct 20, 2005 | 06:03 AM
  #113
Spoolin's Avatar
I didn't have this problem with my E-Manage. But I had the old (gen 1)manifold at the time. I've seen the new (gen 2) compared to the old one and I think the back pressure of the (gen 2) is going to be higher and possibly cause this problem. I still think you need to rule this out just to make sure it's not the problem or part of it.
Old Oct 29, 2005 | 04:39 PM
  #114
Originally Posted by fperra,Oct 14 2005, 11:26 PM
Take off your vtec solenoid and make sure the fine filter screen in not blocked.
Well this say a lot of honda Spain
I took out the VTEC filter and found metalic pieces from the other block.
Then Honda Spain did not adjust the valves, when swapped the block, the clerance was below than should be; 19mm instead of 21mm-25mm
Check the VTEC valve and it was ok.
I made a few runs and oil pressure is at 80 psi, then drops to 65-70 psi when vtec kicks a/F ratio goes to 11:1 in vtec zone at WOT. ( I wanted a very conservative tunnig for hot days at track)
Sometimes feels that vtec does not come in, I have to check again in a empty road.
In case that vtec still doesnt working right what could I do?
oil pressure is always at 80 psi except when vtec kick in.
THX
Old Apr 30, 2009 | 11:41 PM
  #115
03supers2k's Avatar
I know this thread is 4 years old but did you guys ever figure the problem out I'm having this problem and im taking my car to the shop tomorrow
Disgustipated
23
Jun 18, 2011 04:52 PM
ryoga4523
Jun 22, 2009 04:31 PM
AP2S2.2K
May 12, 2008 03:05 PM
CrazyPhuD
Jan 25, 2004 09:41 PM
cjb80
Mar 10, 2002 02:32 AM
