FYI - Denso spark plug failure in FI S2000
I posted this and I'm sure you saw it but let me post here as well.
I was researching through NGK and other site, I found that 7173 is 1 step colder than our stock. according to their web site, you should increase as per 75 to 100 hp increase. notice that our OEM plugs are 1 step colder to begin with. Civic's heat rating is 6.
NGK for OEM 2000
part# PFR7G-11S, Stock# 7772. Platinum tip, 14mm, 3/4" reach, 5/8" Hex. heat Rating: 7, Gap 1.1mm (.044")
NGK for 1step colder
part# R5672A-8, Stock# 7173. 14mm, 3/4" reach, 5/8" hex, heat Rating: 8
NGK for 2step colder
part# R5672A-9, Stock# 7405. 14mm, 3/4" reach, 5/8" hex, heat Rating: 9
I hope someone else can confirm the information I have. also, the gap, I was told to have it between .028 to .030.
cheers,
NGK for OEM 2000
cheers,
Nibble, that actually is very very useful information. As I am changing my current setup I am most likely going to need 2 Head Range Colder Plugs!!!
Now I guess it is about time to stop by the store & pick up some NGK 7405's. Most likely I will have them gapped to 0.030" - 0.032".
Skip, I still have 2-3 unopened boxes of the NGK 7173's - I'll get them up to you sooner or later!
I ain't gonna need 'em, buddy!
either I'll be over 400hp or I will be selling everything... no middle ground for me.
So I guess we'll be testing the 7405's together!
I actually purchased a set of Denso Iridium IK24's from Sparkplugs.com a while back. Put them in my car for about 50 miles & then started hearing of all the problems - just sold them to a local friend for $35.
