gears
Old Nov 30, 2005 | 08:26 AM
  #21
polishprinze's Avatar
What about 4.56 on an turbo ap1 and why is a turbo ap2 better than the ap1?
Old Dec 4, 2005 | 03:35 AM
  #22
jakub2000's Avatar
^start reading what we say...it might help
Old Dec 4, 2005 | 07:26 AM
  #23
GDM S2K's Avatar
Originally Posted by nsxinsac,Nov 24 2005, 02:16 AM
With 302whp at 7.8psi, I had no traction problems with my 245 Kumho's and 17" BBS RGR's and Ohlins coilovers. Get some new and bigger tires and you should be a lot better with traction.
How did your diff hold up? Im planning on making some power and like everyone else the diff is going to be a problem.
Old Dec 4, 2005 | 07:36 AM
  #24
kyo's Avatar
kyo
In my s/ced 05 with stock gearing when i shift at 8k to 2nd or 3rd my wheels break free and i lose traction. If i get 4.57s will this get worse and if so will better tires help.
Old Dec 4, 2005 | 05:21 PM
  #25
casterdog's Avatar
I have an SC 04 with 4.57's and am planning on going back to my stock 4.1. I don't think that once you are over 400hp you should need it and not running at 5000rpm at 80 would be nice.
Old Dec 4, 2005 | 08:45 PM
  #26
kaylins2k's Avatar
y is it that ap2s cannot change to new gearing. is it the added displacment. the.2 liters?
Old Dec 4, 2005 | 09:04 PM
  #27
xviper's Avatar
Of course they can. Lots of people have already done it. Take a look at the following gear calculator:
http://www.turnzero.com/technical_resource...gear_calculator
And check out the numbers for a stock AP1 and a stock AP2.
You will see that Honda has done a great job of gearing the AP2 right from the factory. Based on the available HP of a stock S2000, it is drag limited to about 150 mph top speed, at sea level, on level ground, no wind, standard temperature and pressure. The AP2 is geared to go about the same top speed as it is drag limited. Putting a higher gear ratio on an AP2 would reduce its real world top speed - something that not many owners are willing to do. "Gears" will still help an AP2 accelerate quicker but at a top speed sacrifice.
Now, if you put a blower on an AP2 with "gears", the tires will no longer be able to keep up with the power. On the other hand, if any owner wants to build strictly a drag racing S2000, then the proper gears, blower and tires would make it a very formidable car. But the rest of the world of AP2 owners really don't want a car that has a top speed of 125 mph (I'm guessing here on the ideal geared top speed to best cover the 1/4 mile) and a highway cruising rpm that would numb their brains.
Old Dec 5, 2005 | 10:01 PM
  #28
kaylins2k's Avatar
thanks for the info.. im still new to the force induction scene. i want to go turbo but there are no kits at a very avaible price. my last resort would be SCing my ap2. but that isnt what i want. but the turbo kits out there + tunign will leave me in debt no doubt
maxsales
Nov 6, 2006 09:43 AM
lude92_si
Oct 6, 2006 03:08 PM
rikhemi
Nov 2, 2005 03:37 AM
Sub-Zero
Nov 26, 2003 09:34 AM
