Gears + Turbo
Old May 6, 2009 | 07:09 PM
Nickamsweet's Avatar
Default Gears + Turbo
Atm I am going to be doing a lot of body mods and chassis etc before I spend the
Old May 6, 2009 | 07:15 PM
Revenge's Avatar
Well, take it from me once you start to go over the 300hp range the need for gears becomes less, even more so for a turbo. You need to load the turbo and if the gears are too short you will be out of the gear before you can take full advantage of the HP the turbo makes. I have 4.77 with my turbo, I like it but I can see where if they were closer to stock it would help more once in boost. I think 4.44 300-375hp would be a good choice for a moderate turbo set up but at 500hp you need stock or 3.80's.
Old May 7, 2009 | 04:39 AM
are 3.80 readily available like the 4.77's etc? or are they more custom?
Old May 7, 2009 | 05:02 AM
Revenge's Avatar
You will need to contact the Puddy mod guy on the board he would better be able to help you . Just search for puddy mod.
Old May 7, 2009 | 05:05 AM
RichV's Avatar
500whp + 4.77 gears = never reaching full boost. I definately wouldn't do it! Stay stock.
Old May 7, 2009 | 06:51 AM
S2Kitt's Avatar
His name is Ben and his Screen name is (S2KPUDDYDAD). He is smart as hell, he built me a Stage 2 Diff. w/ a 4.44 gear. Great guy
Old May 7, 2009 | 07:11 AM
MugenRioS2k's Avatar
Originally Posted by S2Kitt,May 7 2009, 08:51 AM
(S2KPUDDYDAD)
He Built my Stage 4 Diff.
Roots supercharger with 4.40 gears
Old May 7, 2009 | 07:29 AM
Spec_Ops2087's Avatar
500+ no need for anything larger then stock gears...
Old May 7, 2009 | 08:09 AM
Thought so...
I have seen so much of his stuff already... read the entire thread about what he does to the differentials!! Great workmanship!! Just the cost of getting it across the pond to Scotland... unless I move to Houston... hmmm
Old May 7, 2009 | 08:29 AM
John_Z's Avatar
True, but 500 with 4.57's are still a lot of fun
