Getting really low numbers on tuned greddy kit
Ok, just wanted to make sure. Looking elsewhere. Time to give us those compression and leak down numbers so we can figure out what's potentially causing the irregularity.
He sent me two pulls, on the VD he's sitting right around 275-280 range on the DJ calculation, which really seems about right to me, it drops to 9psi by redline.
But he is running on openloop tune, and i suggest he got the wideband hooked up to he EMS, car will drive better, and a lot better MPG lol
254whp is low for 10psi, 280whp is not, agreed. However with a pfab log and 3" downpipe and exhaust, id expect it to be in the top end range of expectations for the psi closer to the 300whp mark. Its a tiny turbo though regardless and the F motor breaths so much cfm in the upper range, that size turbo is nearly a choke point for this engine there. You get more peak yield out of an old Novi 1000 super charger at 6psi then a greddy turbo. I've seen consistent reports of 260whp stock out of the box with 6psi and 280-300whp at 10-12psi though on a dynojet roller dyno with greddy.
I'm not sure what you mean, are you referring to my graph? I'm using a Hallman MBC, I know I know I should running a solenoid given the v2 but I had this on hand.
