Going FI
Old Oct 1, 2006 | 01:27 PM
kane.s2k's Avatar
I love how 10psi is now supposedly the new "safe" point
Old Oct 1, 2006 | 02:07 PM
Toad17's Avatar
what do u mean by that... i keep reading everywhere its safe to run 10 psi daily... care to share your thoughts? thanks...
Old Oct 1, 2006 | 04:28 PM
cpoz's Avatar
Take a look at the sig. that's with a gt35r.
Good luck with the turbo
Chris
Old Oct 1, 2006 | 08:25 PM
Toad17's Avatar
thanks guys... damn those are some good numbers.... but thats with a 35r idk wat ill be at with the 3561e.... wat exactly is ur mod list if u dont mind me asking ....
Old Oct 2, 2006 | 06:14 AM
geists2k's Avatar
Originally Posted by kane.s2k,Oct 1 2006, 04:57 PM
That was the exact thing that happened with Geists2k's turbo when he ordered. Instead of waiting around 2 weeks could've just had the gt35r anyways. Oh well, he still made good numbers I forgot the mm on the compressor side already but it might have the same as the gt35r but that cover is smaller/restrictive. When I researched it, it was suppose to peak out at 500hp.
This did push my install back more than it should have, but the Precision 76/60RB works nicely. It spools very quickly and makes some nice power.
Although given the choice knowing I had to make a notch in the frame to accomodate the turbo, I would have just gone with the GT35R.
Old Oct 2, 2006 | 06:27 AM
geists2k's Avatar
Chris
I'm interested to know how you got 471whp on pump gas? I made 399whp (Dynojet) on pump gas and the only difference I can see is you are using the GT35R.
The only difference between your turbo and mine is that I have a slightly smaller turbine. The compressor side is the same.
My tuner was looking at the plugs after each high boost pull and didn't want to go any further than 14psi on pump gas.
I could understand a slight difference in power, but not 72whp. Was this on a Dynojet? How much timing advance are you running?
Old Oct 2, 2006 | 08:33 AM
inlinepro1's Avatar
Hah, CPOZ hit 471whp @ 20lbs of boost. I was there when it was getting tuned for 20lbs...crazy
Old Oct 2, 2006 | 08:52 AM
geists2k's Avatar
So he's running 20psi on 93 octane pump gas?
Old Oct 2, 2006 | 09:28 AM
cpoz's Avatar
Thanks Functional03 (<your def. one of the first people I call when the car is finished!)
Yes I am, and I drive the thing daily for the most part. I really only see about 17-18PSI until I'm really on it(hit 20.5 on Friday night, it was cold outside... lol).
Chris
Old Oct 2, 2006 | 10:26 AM
Toad17's Avatar
damn man those are some really good numbers... but shit 20 psi hahah thats crazy.... i keep readin some people are scared to go to 16 lol.... u have any internals done?
