Going Turbo?
Old Feb 2, 2012 | 02:27 AM
keviinbraah017's Avatar
Banned
Default Going Turbo?
The time has finally come and am ready to put my s2000 on boost. i was thinking about either buying a full bolt or just fabricate my own turbo kit. I'm looking to push around 500-600hp+ and if i put the turbo and push around that much what else would need to be done?
  • Cams
  • Cam heads
  • Valve and Retainers
  • Port heads
  • Low compression pistons
  • Rods
  • i was thinking of buying the 2.4L stroker kit but i heard that reduces your redline to about 7500
Let me know what you guys think and if am missing something else.
Old Feb 2, 2012 | 04:52 AM
hypforlife32's Avatar
none of that first...boost it first. I feel no reason to spend all of that cash because there are MANY people running stock blocks with more then the power you want. Real Street Performance has been revving to 10k+ on stock ap1 block and stock compression with 500-700whp for almost a year or more now...and this should be in a different section.
Old Feb 2, 2012 | 05:29 AM
miguel329's Avatar
yea i went turbo first this time, figured when i put shit load of miles and my engine is tired, i will pull out and have it built. these engine are pretty strong stock! im more worried about my diff and trans lol
Old Feb 2, 2012 | 05:50 AM
Corey Maurer's Avatar
Miguel nailed it, worry about the diff and tranny.. Although of you plan on launching the car I recommend building the head so you can run 2 step
Old Feb 2, 2012 | 06:18 AM
ftpsk8's Avatar
Wouldn't be a bad idea to do springs/retainers/valves, and then just worry about the trans and rear end lol
Old Feb 2, 2012 | 07:06 AM
camuman's Avatar
Boost. Done. My setup is wek saus compared to others and my motor is stock valve cover to oil pan.
Old Feb 2, 2012 | 07:14 AM
bmccoy300ex's Avatar
buy a diff!
Old Feb 5, 2012 | 04:27 PM
Banned
exactly how do i build my tranny and diff? should i build my ap1 tranny or buy a ap2 tranny and build that?
Old Feb 5, 2012 | 04:28 PM
Banned
exactly what do you mean by build your rear end?
Old Feb 5, 2012 | 06:01 PM
jpetch05's Avatar
Go for the full blown 8.8 rear end kit. You can keep a stock motor if you want to run e85 or a higher octane fuel if you want above 500 hp. Otherwise below 5 you can run 93. I hear of some breaking trannys at around 420 whp in 2nd. So try not to unleash until 3rd on up. But for sure do a rear end. And a nice manifold and decent size turbo you should be pretty set.
