Greddy kit installed!
Old Nov 10, 2008 | 03:11 PM
  #51
dsddcd's Avatar
Originally Posted by SgtB,Aug 25 2008, 06:57 PM
I was thinking about it tonight, and I think I figured the noise out. I believe the turbine is spinning fast enough to break up the intake charge, but not fast enough to produce boost . It's like a WWII air raid siren. That's assuming you have the same noise as me, and it only occurs at slow speeds around 2500rpm. It's a steady noise that varies with RPM.
How did you come to that conclusion, what is the relationship between the two that causes that reasonace?
Old Dec 1, 2008 | 09:45 PM
  #52
Olegator's Avatar
Ok, I can officially say that I'm experiencing a "howling syndrome" myself!
I have narrowed down the causes to several things:
The fuel pump
The downpipe design
the thrust bearing (unlikely)
The noise definitely is not coming from the engine bay and is most audible when you are in the car (I have a hard top btw)
The car seems to run normal otherwise.
p.s. I have changed the airfilter out also, but i dont think its the problem
FlushS2000
Oct 1, 2012 02:18 PM
DBXFX
Feb 4, 2009 10:38 AM
Trent06
Jun 21, 2008 08:16 PM
TelosHedge
May 22, 2008 02:29 PM
TurboChargedS2K
Jan 14, 2003 11:46 AM
