Greddy Turbo Install
Old Feb 25, 2008 | 11:07 AM
  #221
S2005x's Avatar
/excited
Starting the install Tuesday when I get off work... Got Wed off, and Thurs/Fri night for the finish... I have a second vehicle I can drive to and from work, so time is no big issue...
Old Feb 25, 2008 | 11:08 AM
  #222
MB's Avatar
MB
Member
Originally Posted by Jouchan,Feb 25 2008, 03:48 AM
Great avatar!! MB! Gan-San Rules!
Old Feb 25, 2008 | 01:07 PM
  #223
Itchy Dick's Avatar
Originally Posted by MB,Feb 24 2008, 10:19 PM
So he is
Want to go for it?
Thinking about it!
It's either turbo my MY00, or go standard MY04 next year??????
Old Feb 25, 2008 | 10:00 PM
  #224
Mr.Aqua's Avatar
I started my install tonight. So far I've removed the battery, front bumper, plastic under covers, heat shield, and the header cover. I'm having problems getting the bolts to loosen up to remove the stock header. any recommendations? WD-40?
I think I'm missing some bolts to. I'm going to double check that now.
tomorrow I plan on removing the header, installing the oil relocation kit and putting the turbo and manifold and down pipe in.
Edit. I think I have all the bolts. But I do have a question. I have a lot of lock washer's. Where should I use these? Do you use them and the flat washer together or just use one? Thanks.
Old Feb 26, 2008 | 01:47 AM
  #225
Itchy Dick's Avatar
I may have missed this part, but do you have to tap the oil pan for the oil return from the turbo?
Old Feb 26, 2008 | 03:35 AM
  #226
AssassinJN's Avatar
No tapping necessary.
Old Feb 26, 2008 | 05:41 AM
  #227
NFRs2000NYC's Avatar
A thousand apologies for a minor hijack, I just didn't want to start another Greddy thread. Assuming I do absolutely no launches, can this kit be handled with a stock clutch? I am planning on changing my clutch eventually, but my car has pretty low unabused mileage. Thanks for the help!
Old Feb 26, 2008 | 06:13 AM
  #228
kix's Avatar
kix
You need penatrating oil for the header bolts. DO NOT try to remove them without blasting them and letting it sit for 20-30 mins.
I used the lock washers (split lock) on my manifold to engine, manifold to turbo, and turbo to downpipe. The other washers I used wherever bolts backing out wouldn't be an issue.
Old Feb 26, 2008 | 06:15 AM
  #229
kix's Avatar
kix
Can't say for sure. I installed my kit with 15,xxx miles. Of those miles I only launched once. I plan on running my kit until the stock clutch dies before I put in a new one.
Old Feb 26, 2008 | 07:38 AM
  #230
SDUECE's Avatar
What kind of motor oil are you Greddy owners using?
