Greddy Turbo Install
Old Feb 23, 2008 | 07:10 AM
  #201
SDUECE's Avatar
Currently I have a Spoon Sports 63mm test pipe and exhaust.
Is that a bad idea to run with the Greddy turbo stock basemap?
If so, why? I'm a noobie with turbo!
I'm not really concerned about the performance aspect at this point with that setup, I'm more concerned if my motor will blow up or relilability issues. Would there be problems running a test pipe? Am I better off running the stock cat w/ the Spoon exhaust, or I'll be fine with the test pipe and exhaust?
Old Feb 23, 2008 | 07:35 AM
  #202
S2005x's Avatar
I'll be putting my cat back on, and running stock exhaust until I can get it tuned, them im going to run an exhaust and a 70mm tp.
Old Feb 23, 2008 | 10:01 AM
  #203
JoeyBalls's Avatar
Im going with a Custom Exhaust, stock cat for now, the Greddy Kit was tuned with stock Cat, but larger exhaust.............
Old Feb 23, 2008 | 10:29 AM
  #204
Mr.Aqua's Avatar
I'm waiting on getting a new oil line that goes to the turbo. In the mean time can I install the Walbro Fuel pump and nothing else and still drive the car? Any issues with this?
Old Feb 23, 2008 | 11:31 AM
  #205
S2005x's Avatar
Originally Posted by honda_s2k_racing,Feb 22 2008, 12:58 PM
Looking to order several things now to add onto what the kit is missing.
First up, BOV and Flange:
BOV: http://www.sportcompactonly.com/GReddy/Blo...-19_p-17988.htm
Flanges: 19mm - http://www.sportcompactonly.com/GReddy/Blo...b-19_p-1199.htm
32mm - http://www.sportcompactonly.com/GReddy/Blo...-19_p-63602.htm
Question, which Flange do I need? 19mm or 32 mm? Also, is this a good price (click the links). Thanks.
And Lastly, My Hood, think it can cause problems with water draining in?
Still need answers
Old Feb 23, 2008 | 03:12 PM
  #206
kix's Avatar
kix
Originally Posted by kix,Feb 22 2008, 11:27 AM
http://www.sportcompactonly.com/GReddy/Blo...-19_p-54982.htm
You need this flange. The ones you listed above are for recirculation (I think). Problem is there's not much descriptions on the website to tell what they are.
The two links you have for the UEGO gauges are different in that one comes with the wideband senosr and the other does not. Again, this website sucks in listing model #'s so its difficult to see what other differences there are.
In terms of pricing, be sure to call some shops/sponsors here. If your lucky you'll find one that even beats EBAY's prices.
The only other question that is not answered is the water leaking in. I would worry about your hood leaking water onto the filter. Thats about it
Old Feb 23, 2008 | 10:47 PM
  #207
SDUECE's Avatar
So why is everyone running the stock cat with Greddy basemap and then the test pipe when time to retune?
What kind of problems would occur if installing a test pipe with Greddy basemap?
Old Feb 24, 2008 | 04:21 AM
  #208
sparrow's Avatar
air fuel ratio would change enough that the basemap would not be able to compensate for it...which could be VERY BAD...possibly boom!
Old Feb 24, 2008 | 06:16 AM
  #209
MB's Avatar
MB
Member
This is a brilliant write up, well done.
I woudl love to know if anyone has this on a RHD car?
Old Feb 24, 2008 | 06:26 AM
  #210
S2Kart's Avatar
Maybe, but I really doubt it.
Even at 10 psi and a Berk high flow cat my base map was very rich - 10.2:1. A test pipe flows only about 10% better. At the normal 7-8psi boost, base map, and upgraded exhaust, I'd bet money its still rich. Try it at your own risk
