Greddy Turbo Install
Old Mar 1, 2008 | 12:59 PM
  #321
SDUECE's Avatar
Hey Guys, another Greddy owner here! This thread is helping me out a lot!
I've started my install yesterday and now I'm installing the intercooler. I'm haviing trouble with it hitting the AC condenser. Am I missing a bracket? Do I have to bend the bracket? Can you guys help me out with this part?
Old Mar 1, 2008 | 01:00 PM
  #322
S2005x's Avatar
Mine did that too... not sure... but I just bolted it up and the intercooler is touching it...
Old Mar 1, 2008 | 01:16 PM
  #323
kix's Avatar
kix
Mine bolted up just fine but has prob 1mm clearance. You can drill out the holes in the bracket and intercooler mounts to give you some extra clearance tho.
Old Mar 1, 2008 | 01:21 PM
  #324
S2005x's Avatar
ugh, the anticipation is killing me! TUESDAY NIGHT! GAH
Old Mar 1, 2008 | 01:24 PM
  #325
S2005x's Avatar
BTW, kix, i ordered the flange and BOV... ill find someone down here to weld it on for me...
Got a sound clip of yours? I dont want a loud ass BOV...
Old Mar 1, 2008 | 02:00 PM
  #326
S2DEX's Avatar
[QUOTE=SCG-Milan,Mar 1 2008, 09:25 AM]I've also heard A LOT about not using Royal Purple on a turbo car.
You spent $70 on oil?
Old Mar 1, 2008 | 02:49 PM
  #327
Envied's Avatar
Well, Amsoil really isnt that much more than RP.. 7.70/qt where RP is like 7.49/qt at my local pep boys. The only difference is you cant just go to the store to get amsoil. You have to go through a distributor or get it online from amsoil.
Old Mar 1, 2008 | 02:55 PM
  #328
Mr.Aqua's Avatar
I just put in the Walbro fuel pump.. it took me about 2-3 hours to do what a PITA. One of the hardest parts was trying to disconnect the electric connector form the OEM fuel pump. I had to use pliers and a pair of tweezers to remove it. And putting the fuel filter stay (tiny metal o ring) on isn't a walk in the park. I used pliers and a screw driver. You have to be careful not to block the traveling path of the fuel level arm. I had to adjust it several times to it it right. If you tall like I am its very hard working in the small space behind the seats. My neck is going to be killing me tomorrow!!
Old Mar 1, 2008 | 05:39 PM
  #329
kix's Avatar
kix
^HAHA... from your last few posts with all the issues your having I'm thinking your 6'2" and weight about 190lbs.
What else do you have left?
Old Mar 1, 2008 | 06:10 PM
  #330
Chris_Lum's Avatar
The intercooler has some play before you tighten the brackets, so push it forward and tighten the bolts, OR bend the AC pump bracket back a little.
