Greddy Turbo Install
Old Feb 27, 2008 | 05:00 PM
  #291
DjSkrilla's Avatar
From stock Ap1 exhaust /w cat to single 3inch InlinePro /w TP.
Old Feb 27, 2008 | 07:53 PM
  #292
devs2k's Avatar
why are you guys hung up on absolute power/tq numbers?? only relative numbers matter, as i showed a few posts ago comparing a stock ap2 to kix's...
Old Feb 27, 2008 | 08:41 PM
  #293
parkerdw's Avatar
I think your numbers are fine given the exhaust you are currently using. Your delta is about 82 hp and mine is about 100 hp, but my exhaust is slightly larger than the one you are using, however Im also using a high flow cat and not a test pipe. My boost pressure also peaks at 9psi.
Also, Church has already tuned a greddy turbo s2k and the dyno was posted. I'm too lazy to look up the thread. The number was 319 on that dyno, but only s2kart is running at 10psi full time, which explains in part why he has posted the highest numbers and largest delta. I think you can get another 20 - 25 hp easily with a new exhaust.
Old Feb 27, 2008 | 10:07 PM
  #294
NFRs2000NYC's Avatar
I have an HKS exhaust, and REALLY don't want to get rid of it. Can I still use it with the kit? (I will get a test pipe and tune probably a few weeks after the kit is installed.)
  #295
f23power's Avatar
this is by far...the BEST thread ever in my 1.5 years of posting here on s2ki
-a
Old Feb 28, 2008 | 03:07 AM
  #296
LBP AP2's Avatar
Freakn Awesome Forum. Good luck with everything. Really Really Really helpful.
Old Feb 28, 2008 | 05:36 AM
  #297
JoeyBalls's Avatar
I am going with the Invidia Exhaust, its 70mm which is the same if not slightly larger then the downpipe with the Greddy Kit, so I would imagine this would be good breathing exhaust..........and for the $, you really can't beat it
Old Feb 28, 2008 | 06:56 AM
  #298
devs2k's Avatar
did you any feedback on running a 80mm? i saw your thread but maybe you've asked elsewhere as well
Old Feb 28, 2008 | 08:12 AM
  #299
Nyther's Avatar
Originally Posted by Nyther,Feb 27 2008, 05:22 PM
I heard that you could do something with the wastegate on the greddy kit, placing a larger wastegate-valve ( or how do you call that round thingie that opens up? ) and make the wastegate hole slightly bigger..
but im my opinion this should give more stable boost? not increasing boost?
Can anyone chime in on this one? i've read about this wastegate-mod on the greddy turbokit in a older topic, can't find it anymore
Found the actual topic, i ment "porting the wastegate"
link: porting wastegate greddy turbo
who already tried this?
Porting the wastegate hole and welding a bigger flapper
Old Feb 28, 2008 | 10:13 AM
  #300
JoeyBalls's Avatar
Well, Im getting that it really won't make that much of a difference, for the amount of air the Greddy Kit will push through the system. The downpipe is 70mm I believe or smaller so the 70mm Invidia should be fine, at least it is all Mandrel bent with nice burnt tips, I was going to have the bending done at a muffler shop I am sure it wont be as nice as the Invidia, plus this way is $600 cheaper
