Greddy Turbo Install
Old Feb 22, 2008 | 04:57 AM
  #191
SOHCmyDOHC's Avatar
Originally Posted by JoeyBalls,Feb 22 2008, 05:51 AM
I talked with a shop Yesterday here in NJ, they are going to Manderal Bend me a Custom 3" Stainless Steel Exhaust for $900.00 I am bringing them two 3" Stainless Steel Magnaflow Mufflers and they are going to weld on my stock '04 Tips. I guess it will look like the Comptech with bigger piping. I couldn't find a 3" Cat Back exhaust anywhere so I figured I would go Custom I will post pics as soon as I get it done.
Have you checked out the ASURA design cat back?
https://www.s2ki.com/forums/index.php?showtopic=565432
Old Feb 22, 2008 | 04:58 AM
  #192
S2Kart's Avatar
Originally Posted by Mr.Aqua,Feb 21 2008, 11:48 PM
quick question about the install. My oil return line that goes from the oil pressure switch to the top of the turbo sounds like it has a small bb or something rattling around in it. Is this normal? Thanks!
The threaded collar at the end is a separate piece, so maybe you are hearing it as it taps on the flared end of the actual tube? If you hold the threaded collar against the tube you shouldn't hear anything if you shake the tube.
Old Feb 22, 2008 | 05:09 AM
  #193
JoeyBalls's Avatar
I did, I had already purchased the Mufflers and couldn't return them, which is unfortunate becuase I would have much rather had the ASURA Exhaust then some random place make mine
Old Feb 22, 2008 | 07:36 AM
  #194
kix's Avatar
kix
Are you sure its not just the two end fittings that are rattling? Perhaps you can hold those two down and see if you could reproduce the rattle
EDIT:
Someone already replied.... should've scrolled down first!
Old Feb 22, 2008 | 08:25 AM
  #195
Mr.Aqua's Avatar
I held down the two ends and tilted it back and forth. Something definately does go from one end of the line to the other. To clarify the part I'm talking about is part # 34. Looks like I'll have to call greddy and get it replaced.
Edit: Called Greddy and they said that's not normal.
Old Feb 22, 2008 | 09:58 AM
  #196
S2005x's Avatar
Looking to order several things now to add onto what the kit is missing.
First up, BOV and Flange:
BOV: http://www.sportcompactonly.com/GReddy/Blo...-19_p-17988.htm
Flanges: 19mm - http://www.sportcompactonly.com/GReddy/Blo...b-19_p-1199.htm
32mm - http://www.sportcompactonly.com/GReddy/Blo...-19_p-63602.htm
Question, which Flange do I need? 19mm or 32 mm? Also, is this a good price (click the links). Thanks.
Second up, Gauges. I'm Going AEM and here is what im thinking.
TruBoost - http://www.sportcompactonly.com/AEM/Gauges...b-1_p-91401.htm
UEGO - http://www.sportcompactonly.com/AEM/Gauges...b-1_p-83522.htm
- http://www.sportcompactonly.com/AEM/Gauges..._b-1_p-4077.htm
Question, are these good prices? Also, I found several types of the UEGO gauge... which one do I need?
And Lastly, My Hood, think it can cause problems with water draining in?
Old Feb 22, 2008 | 10:27 AM
  #197
kix's Avatar
kix
http://www.sportcompactonly.com/GReddy/Blo...-19_p-54982.htm
You need this flange. The ones you listed above are for recirculation (I think). Problem is there's not much descriptions on the website to tell what they are.
The two links you have for the UEGO gauges are different in that one comes with the wideband senosr and the other does not. Again, this website sucks in listing model #'s so its difficult to see what other differences there are.
In terms of pricing, be sure to call some shops/sponsors here. If your lucky you'll find one that even beats EBAY's prices.
Old Feb 22, 2008 | 11:45 AM
  #198
S2005x's Avatar
Ok, cool. So, The BOV on the site is the one I need, but the flanges are wrong?
Wheres the best place to get those?
Old Feb 23, 2008 | 03:58 AM
  #199
Nyther's Avatar
great topic!
a few small questions
1: with a stock s2k i can expect 270WHP/ 330hp crank?
2: If i add a 70mm testpipe, get i problems such as boost spike? or is it just plug and play and i have a few ponies more ( 15 or something? )
3: Some people say the power is limited due to heat? can somebody explain this?
4: Since im in europe, we have octane 98 here. does this give problems with the pre tuning of the greddy basemap compared to US fuel? since i heared you have lower octane ratings...
I'm gonna order my greddy kit next month
for all the good replies here!
Old Feb 23, 2008 | 05:03 AM
  #200
JoeyBalls's Avatar
With A test Pipe, upping the Boost and a Good tune, I would xpect close to 330WHP rather then crank............
