Greddy Turbo Questions thread....
Old Mar 24, 2008 | 09:13 PM
  #271
S2005x's Avatar
/cry
Is there not going to be a greddy 70mm dual?
I want a dual soooo bad
Old Mar 24, 2008 | 09:32 PM
  #272
Chris_Lum's Avatar
nope, sorry. Single is the way to go!!!
Old Mar 24, 2008 | 09:48 PM
  #273
AP1NYT's Avatar
You can buy my t1r dual sparrow so i can get the single greddy coming out
Old Mar 24, 2008 | 09:53 PM
  #274
UberDuper's Avatar
Berk has a dual they claim flows as well as an 80mm single at the sound level of a 70mm single. There was a thread about it somewhere on here. Don't recall if anyone was using.
UD.
Old Mar 24, 2008 | 11:21 PM
  #275
NFRs2000NYC's Avatar
Hey, to the guys with UEGOs....
How are you running the wiring to the engine bay? I noticed that the wrapping on the wiring is not heatproof, and the hot downpipe might cause it to melt. Just curious as to how you guys are running the wiring from the AFR sensor into the engine bay?
Also, for a BOOST only source (no vacuum)....
Can I tap into the nipple that says GREDDY or do I tap into the nipple of the wastegate?
Old Mar 25, 2008 | 07:15 AM
  #276
Sinji's Avatar
if your turbo has that nipple there then yes. for the turbo kit the nipple for the boost reference source is on the first outlet pipe coming out of the turbo
Old Mar 25, 2008 | 08:16 AM
  #277
S2005x's Avatar
o0 Dual 70mm?
How much? Shipped.
Old Mar 25, 2008 | 10:14 AM
  #278
ZSAK's Avatar
hey another question for you guys. Once you got your kit installed were there any rattles or odd noises that shouldn't of been there or did the kit fit as if it were an oem product;
Old Mar 25, 2008 | 10:17 AM
  #279
S2005x's Avatar
I have slight rattles/vibrations... at very low rpm... just above idle...
at idle, its perfect, and above about 2500, no problems... but that raddle is bugging the piss out of me...
Also, when i make hard left turns, i hear wierd noises... like rougher vibrations as if the turbo itself is touching the frame of the car...
Dosent do it on hard right turns...
Old Mar 25, 2008 | 11:38 AM
  #280
Chris_Lum's Avatar
point of advice for a searching for rattling noises.
1.
if you have the exhaust manifold heatshield connected to the valve cover by the bracket (like how the instruction manual states), take it off!!! that only creates rattling problems since the motor torques, and the heatshield isn't supposed to move.
2.
Make sure none of your compression pipes are touching the air diversion panel...these often get close and rattle as well.
3. Make sure all compression pipe and intercooler brackets are tightened well.
