head gasket
Old Feb 4, 2009 | 05:27 PM
killabee's Avatar
Default head gasket
I was just wanted to know from you guys that have changed out your head gaskets did you have to remove the wire harness from your knock sensor when removing the head off the block? and If so I heard that If you have a late year s2000 that the sensor gets old and will break when you try to remove It. just want to know what to look for If paying a shop to do it so I dont get taken for a ride.
Old Feb 4, 2009 | 05:54 PM
ChefJ's Avatar
I don't think I took anything apart on that side. I didn't remove the intake mani from the car though when I wapped my headgasket out.
Old Feb 4, 2009 | 08:18 PM
Soul Coughing's Avatar
no you dont. just make sure you take the connector for the crank position sensor off the intake plenum.
Old Feb 5, 2009 | 07:58 AM
killabee's Avatar
anyone eles?
Old Feb 5, 2009 | 08:23 AM
Originally Posted by killabee,Feb 5 2009, 11:58 AM
anyone eles?
the wire harness does not need to be removed off of the knock sensor when taking the head and IM off. Look in the helms if you need more insight...
Old Feb 6, 2009 | 06:51 AM
killabee's Avatar
Ok this Is great Insight. Here Is the real story. I am having a 3mm headgasket put on by a local shop. They call me up and say In order to remove the head that they need to remove the harness from the knock sensor and that since mine is a 2000 that there Is a chance that It would break when they go to pull It off. so I say go for It and they call me back and tell me that It did break. can anyone give me more testomny before I put someone on blast.
Old Feb 6, 2009 | 06:57 AM
the knock sensor is super fragile. A friend was helping me put the head back on the block and hit the knock sensor with his hand and it broke. I'm betting they had already broken the sensor when he called you and wanted to see if you would cover it as its a 130 dollar piece.
Old Feb 6, 2009 | 09:15 AM
killabee's Avatar
yeah they are trying to charge me 168.00. I thought the same thing thats why I posted on here so I could get some feedback. I am going to check my honda shop manual and see If says to remove the knock sensor. I am trying to down load It now unless someone has one and can look threw It for me.
Old Feb 6, 2009 | 09:30 AM
you can download it for free if you look on google.
Old Feb 6, 2009 | 10:03 AM
killabee's Avatar
Soul Coughing thanks for your help with this matter and to anyone eles who posted on thread. I downloaded the manual and nowhere In It does It say to touch the knock sensor. I am going to pick my car up now i will let you guys know how It turns out.
liybzd
Jan 31, 2014 02:19 PM
Brndon
Aug 2, 2013 04:50 AM
rjbecker12
Oct 5, 2012 08:29 AM
s2kseven
May 21, 2012 10:19 AM
seoul2k
May 4, 2011 03:18 PM
