head gasket and cam clocking questions
Old May 7, 2009 | 05:22 PM
2jztuned's Avatar
Default head gasket and cam clocking questions
does the ap1 and ap2 use the same head gasket?
Old May 7, 2009 | 05:25 PM
dsddcd's Avatar
Yes they do for future reference try www.cheaphondaparts.com and check the Pt#'s, however there are several instances where there are different numbers for interchangeable parts.
There are no dumb questions, just dumb answers.
Old May 7, 2009 | 05:30 PM
2jztuned's Avatar
cool. i have an inline pro 3mm head gasket and was thinking about putting it on my 06. well decided after pricing the engine build lol. i have tried to search on the cam clocking and havent really found a good thread on it so far. any ideas?
Old May 7, 2009 | 05:44 PM
neeman77's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry11819424
there you go bud.
Old May 7, 2009 | 05:54 PM
2jztuned's Avatar
thanks man i appreciate that. i dont know why i could find it. guess i dont know how to use the search engine. so basically you just knock out the dowl pin?
Old May 7, 2009 | 06:05 PM
AusS2000's Avatar
And clock the cogs whilst tightening it. It only moves about a degree.
neeman77's Avatar
Yep, knock it out and turn the inner gear. Once you finish it you will think to yourself " Is that all it moves? Was this actually worth the effort?" The answer is yes. lol.
AusS2000's Avatar
BTW, it's not a dumb question, but it is a dumb title for a question as nobody with the same question will find it.
Old May 7, 2009 | 06:08 PM
2jztuned's Avatar
lol that is true. ill change the title. so you are basically just taking out the slack? also are the f22's interference motors?
Old May 7, 2009 | 06:10 PM
neeman77's Avatar
You are actually using the slack that is preexisting to adjust the cam where you want it when the pin is removed. The bolts hold it in place at the furthest point of "slack". Yes the f20/f22 is interference.
