head gasket and low compresion pistons
Old Apr 2, 2007 | 02:39 PM
s2kjb's Avatar
Default head gasket and low compresion pistons
i am currently building my motor for turbo and im going to be using 9:1 but should i also use a 3mm head gasket?
just curious
Old Apr 2, 2007 | 03:05 PM
afwfjustin's Avatar
Any reason why you're not going with HG only? A lot of people run them safely.
snakeeater's Avatar
No. 9:1 is low enough for 25 psi of boost on race gas. Adding a 3mm HG will drop you down to about 7:1 with those pistons.
Old Apr 2, 2007 | 03:11 PM
s2kjb's Avatar
afwfjustin- dropped a valve so im building the engine if i had a choice i would go with just a different head gasket.
keeater- i kind of figured that but thanks for confirming
Old Apr 2, 2007 | 03:19 PM
XclusiveAutosports's Avatar
Nope, there is no need for it. You need some type of compression, and with a built bottom end on 9:1 compression you are good to go.
Old Apr 2, 2007 | 04:10 PM
afwfjustin's Avatar
Ouch... yeah you're doing it "right" then. The 9:1 pistons will be plenty for you. Boost away
teddy11
Feb 26, 2009 01:42 PM
d.h
Mar 30, 2007 05:24 AM
20vmini
Jan 17, 2005 06:02 AM
Honda-S2000VTec
Aug 20, 2003 10:08 AM
SuzukaS2K
May 16, 2003 10:00 AM
