Being safe on high psi?
Old Mar 29, 2007 | 10:44 PM
d.h's Avatar
d.h
Default Being safe on high psi?
I've been searching around the forum and got the impression that our engine can go up to 10psi without doing any work on the motor. And if one wants to up the boost past that, they lower the compression by putting in a head gasket in order to be safe.
My question is.....let's say I go 12psi or up with a 3mm head gasket. To make sure that the motor doesn't blow up, would I have to do work on the head or the block to support the high boost, or just the head gasket will do it?
Old Mar 29, 2007 | 10:47 PM
afwfjustin's Avatar
By lowering the compression, you are able to boost higher and it makes up for it since 1 pound of boost makes more power than a point of compression. By lowering comp. and boosting higher, you are able to keep the same total compression (comp. + boost). It's actually more like 9 pounds on stock comp. btw, 10 is really really pushing it (you need to account for things like boost creap/overboosting).
I'm sure someone will come in soon with a neat little formula with how it works out
Old Mar 29, 2007 | 10:53 PM
Spec_Ops2087's Avatar
It really all comes down to the tune to consider what is safe on a stock engine and what isn't. You pull a lot of timing and richen her up, you could go past 10psi safely for WOT runs. I creep a little past 10psi when going WOT in like 3+ gear for a few seconds but my tune is safe enough that it doesn't concern me to much.
Old Mar 30, 2007 | 04:48 AM
j_c_a's Avatar
The tune is everything. This engine can handle a lot more boost than people give it credit for, but ONLY if your tune is good.
I run 22 psi on a daily basis w/ a 3mm HG and stock block/head. With my tuner I'd be confident running up to 25 psi but I'm out of injector.
Having said that, you can blow a motor on very little boost if your tune is bad.
Old Mar 30, 2007 | 05:21 AM
C45P312's Avatar
damn, how much you put down.
Old Mar 30, 2007 | 05:24 AM
OGPackin's Avatar
I just had mine tuned to 24psi and my tuner is confident i could boost to atleast 26psi without a problem. Tuning is key...
teddy11
Feb 26, 2009 01:42 PM
s2kjb
Apr 2, 2007 04:10 PM
passmans2kny
Jul 5, 2006 05:31 AM
20vmini
Jan 17, 2005 06:02 AM
Honda-S2000VTec
Aug 20, 2003 10:08 AM
