Helio Coil kit
Hi,
I am repairing my head with the Helio coil since it is stripped and was wondering if that will hold boost. I want to know if anybody has ever used the Helio to repair the head and is it reliable. Thanks!
DO not use a helicoil for a sparkplug.
There is another insert called a Timesert which is a threaded collar that is expanded into an oversized threaded hole. It seals just like an original thread.
Helicoils are a spiral of stainless that is wound into an oversized thread. Problems can be if it grabs on the plug and starts to wind itself in or out with the plug, and also as its inserted into an oversized thread the spark plug is partially seated on the top of the helicoil.
The timesert comes with a tool that cuts a stepped recess at the top of the thread and the collar has a stepped top. Once its installed the toolkit includes a cutter to cut the top flush with the head.
Chris.
Chris.
Been there, done that. Didn't work.
