Helio Coil kit
Old Nov 26, 2008 | 04:54 PM
CTECHs2k's Avatar
Default Helio Coil kit
Hi,
I am repairing my head with the Helio coil since it is stripped and was wondering if that will hold boost. I want to know if anybody has ever used the Helio to repair the head and is it reliable. Thanks!
Old Nov 26, 2008 | 06:42 PM
dsddcd's Avatar
Should hold great if it is done correctly.
Old Nov 26, 2008 | 06:43 PM
neeman77's Avatar
One of my friends repaired 2 threads for headstuds on his block and it was able to hold 20 psi for the past year at 456 hp in his integra.
Old Nov 26, 2008 | 08:58 PM
AusS2000's Avatar
Properly installed helicoils will be stronger than the original threads.
Old Nov 26, 2008 | 09:13 PM
CTECHs2k's Avatar
Ic cool thanks...that made me feel alot better...
Old Nov 26, 2008 | 10:20 PM
chris_barry's Avatar
DO not use a helicoil for a sparkplug.
There is another insert called a Timesert which is a threaded collar that is expanded into an oversized threaded hole. It seals just like an original thread.
Helicoils are a spiral of stainless that is wound into an oversized thread. Problems can be if it grabs on the plug and starts to wind itself in or out with the plug, and also as its inserted into an oversized thread the spark plug is partially seated on the top of the helicoil.
The timesert comes with a tool that cuts a stepped recess at the top of the thread and the collar has a stepped top. Once its installed the toolkit includes a cutter to cut the top flush with the head.
Chris.
Old Nov 27, 2008 | 08:34 AM
neeman77's Avatar
Yes that is what I was refering to, not the simple helicoils that are used for spark plugs.
Old Nov 27, 2008 | 11:48 AM
CKit's Avatar
Been there, done that. Didn't work.
stand_firm
Sep 19, 2016 11:00 PM
cajunap1
Sep 29, 2011 06:10 AM
noxcus
Jul 13, 2011 09:11 AM
ILOVEMYAP2
Mar 24, 2010 09:28 PM
Nobody
Jun 23, 2006 12:15 PM
