Help!
Old Mar 14, 2011 | 03:08 PM
Blacknizzle69's Avatar
Default Help!
I just finished installing my Mase Turbo Kit. I also installed Hondata K-Pro. The car won't start. Its def getting fuel and I loaded the S2000 ap1 map on KManager. Does anyone have any ideas on what it could be?
Old Mar 14, 2011 | 05:35 PM
o'malley_808's Avatar
Did you have the head off or engine wire harness off for any reason? What else have you changed? More info needed to help ya out!
Old Mar 14, 2011 | 06:49 PM
For Kpro to work, I have to pull off the valve cover and timing cover to replace the cam sensor wheel and crank sensor wheel, and both sensors. Im 100 percent sure I put the wheels on the correct way, all the connectors on the harness are connected.
Old Mar 14, 2011 | 07:28 PM
DFWs2k's Avatar
is it getting power, is the immobilizer key flashing
Old Mar 14, 2011 | 11:27 PM
Its getting power, immobilizer is disabled
Old Mar 14, 2011 | 11:49 PM
jaundice's Avatar
Check all of your coil connections (these were undone when you pulled VC off) and make sure you have 4 connectors into the KPro unit itself. Did you change the MAP sensor also? You have to configure that in KPro. Did you change injectors? You have to configure that in KPro. Are all of these sensors plugged in? Did you pull the exhaust cam out to change the sensor wheel? If you did, are the timing marks correct when you put the cams back in? Start there. Let us know.
Old Mar 24, 2011 | 09:59 PM
Car has no spark...checked the grounds and there all in tact, think the crank reluctor wheel could cause no spark?
Chief Robert
Aug 27, 2019 12:37 PM
Ap1hero
May 22, 2018 10:27 AM
rjbecker12
Oct 5, 2012 08:29 AM
jaundice
Feb 23, 2010 08:30 AM
UsmcSway
Oct 22, 2008 05:23 PM
