help! can you run AP2 vortech on a AP1?
Old Sep 5, 2008 | 03:16 PM
mustangkiller01's Avatar
Default help! can you run AP2 vortech on a AP1?
i'm looking at a good deal on an ap2 vortech kit. I know they use a sumplementary injector in the power cooler that isn't use on the ap1, i would think the black timing box would also need to be tuned for an ap1, and the pully is smaller (4.5) than that of a ap1 kit....i was told that if i run that pully on a ap1 it will make around 12psi which is to much on a stock motor.... any input?
thanks a lot
Old Sep 6, 2008 | 07:16 PM
shawnAMT's Avatar
The black box you will need one for AP1. You wont use the 5th injector. I think teh 4.5 pulley will yield around 10 psi but not sure on that one. There is a pulley chart in the FAQ that should show you.
Old Sep 6, 2008 | 07:31 PM
Enthralled's Avatar
you'll need some injectors and a ems. and 4.5 pulley should be 10psi.
Old Sep 6, 2008 | 08:39 PM
shawnAMT's Avatar
correct about the engine managment and injectors. I would go with the 750cc just incase you decide for more power they will give you enough. It sucks deciding you need more power and your injectors are too small...been there done that..might as well get it right the first time
Moddiction
Apr 6, 2011 05:01 PM
wing
May 30, 2009 07:12 PM
08s2000CRbackinblack
Oct 12, 2008 08:42 PM
dean
Oct 30, 2007 04:50 PM
modMonkey
Oct 1, 2007 06:14 PM
