HELP INSTALLING BOOST GAUGE
Old Feb 20, 2015 | 05:07 PM
s2kfreak69's Avatar
Default HELP INSTALLING BOOST GAUGE
HEY GUYS SO IM DONE INSTALLING MY WHOLE GREDDY TURBO KIT I JUST NEED TO INSTALL BOTH MY BOOST AND AIR FUEL GAUGES
IM ALITTLE CONFUSED FOR TEE IN SUPPOSE TO CONNECT ON WHICH HOSE
AND ALSO
WIRING THE AEM AIR FUEL GAUGE
PLEASE HELP THANKS!!!
PICTURES WOULD BE GREAT IF YOU CAN POST THEM!
Old Feb 20, 2015 | 05:11 PM
Moddiction's Avatar
Former Sponsor
Wideband obviously connect the wideband sensor and then wire the power and ground into the car. You can just tap into another 12v ignition power source or get one of those fuse adapters to get power that way without any splicing or anything.
Boost just t off one of the vacuum lines. You could use bov line as well.
I'm sure there is plenty of info and pictures with a quick google search.
Old Feb 22, 2015 | 06:34 AM
s2klariat's Avatar
I used the nipple on the intake manifold that was part of the secondary air injection system for the boost gauge. Works fine. Wire the power to the 12v switched input beside the fuse box on the driver side of the car, and ground it where the other grounds are.
s2kfreak69
Feb 20, 2015 04:59 PM
S2Kwikat9k
Jul 9, 2008 06:26 AM
Wahooz
Apr 5, 2008 07:17 PM
wannabuy
Jul 12, 2004 12:13 PM
scs2000
Oct 4, 2002 12:53 PM
