Help with mase turbo kit
i bought a mase turbo manifold and downpipe to replace my revhard log setup. I'm trying to figure out what needs to be modifiyed.
1 The down pipe also most hits the vtec pressure sensor on the vtec solenoide and the plug for the sensor can not be pluged in cuz it hits the downpipe.
2. The water pipe outlet for the stock oil cooler almost touched the manifold making it impossible to put a hose onto the water pipe.
From my searching i believe i take the vtec pressure sensor off and plug it because it is not needed when you have a aem ems which i do have. is this correct?
also from reading and looking at pics i believe the water pipe for the oil cooler needs to be cut and shortened and re welding so there is enough clearance for the hose to fit
It this correct???
It this correct???
thank you for your help guys. i though i was going crazy. i was up all night changing out my rev hard log to the mase manifold and i though i was going crazy, wandering why this was not fitting correctely.
what is the size of the bolt i need to plug the vtec pressor sensor? Since i do not need this sensor vtec will still work right? since i'm useing an aem ems correct?
cant i just use this location for a turbo oil feel source?
lude9285
Mar 17, 2016 01:18 PM
superslows2k
Nov 11, 2009 06:45 AM
