HELP NEEDED FAST!
Old Nov 5, 2005 | 05:07 AM
Scorpion's Avatar
The fan on the drivers side is the AC fan. It will only turn on when the AC is in use. If you have a shop manual try doing the trouble shooting steps that's in there. Though I really believe it's a configuration issue with the EMS. I'll take screen shots later of the configs and post them to see if they help.
Old Nov 5, 2005 | 06:13 AM
GoFaassttt's Avatar
Thanks Scorpion. I would like to see those.
Old Nov 5, 2005 | 06:44 AM
fperra's Avatar
The only two things common to both the radiator fan and the condenser fan are the 7.5 amp fuse under the dash on the drivers side, and ground point G201. G201 is the star grounding point just to the right of the top of the radiator on the right side of the engine bay. That was my problem. This morning I took that ground apart, cleaned all the contacts, put it back together, and everything is working now. To late for the autocross though.
Old Nov 5, 2005 | 08:29 AM
John_Z's Avatar
I tried to get the fans to kick on but they would not. I would like to see how to do this also.
Old Nov 5, 2005 | 11:00 AM
jakub2000's Avatar
Both of my fans were running 3 weeks ago,so I hope to be able to solve it the same way you did.Can't be the configuration of the ESM in my case since they both worked, so I hope it's mechanical.
How can a ground go bad?!?!???
Stoatmaster
Nov 4, 2015 01:32 AM
mhansen146
Jul 6, 2013 01:20 PM
o'malley_808
Jul 20, 2011 12:01 PM
nartnailuj
Oct 1, 2010 05:20 PM
jwa4378
Dec 29, 2008 05:06 PM
