Help Oil Feed to turbo
Old May 12, 2010 | 10:23 AM
rsxiness03's Avatar
Default Help Oil Feed to turbo
OK so before i start the car i was curios if the method used in the pictures will provide substantial amounts of oil to the turbo.. i ran a t fitting off the sandwich plate off the block...one side is blocked and the other connects to oil feed...is that fine will it provide the turbo with enough oil
Old May 12, 2010 | 11:27 AM
itlynstalyn's Avatar
The T fitting is more than likely for a pressure sensor or oil cooler. If you're not running either, pull the plug out of the flat end of the t fitting and reinstall it into the port where the t fitting is now.
You should probably just start asking your questions in the Greddy thread instead of starting a new one every time you need help, it just tends to clutter up the FI section
Old May 26, 2010 | 07:05 PM
rsxiness03's Avatar
bump
Old May 30, 2010 | 05:57 PM
rsxiness03's Avatar
bump looking for an answer oh and the sensor is in stock location
Old May 30, 2010 | 07:50 PM
Trackforged's Avatar
Former Sponsor
From the looks of the fitting it's a -4. Make sure your turbo has an oil restrictor either built into the center section and if not then get one that will slow oil flow to the turbo. A restrictor that is .065 is what you will be needing for a small or medium frame journal bearing turbo. Running a -4 straight to the turbo, if no restrictor exists, you will run the risk of pushing oil past the seals in the turbo and thus killing the turbo.
John Grant
Old May 30, 2010 | 08:15 PM
rsxiness03's Avatar
doesnt the greddy kit come with an oil restrictor from factory?
Old May 30, 2010 | 08:24 PM
Chris_Lum's Avatar
the greddy kit has an oil restrictor built into the union fitting that connects the oil feed and turbo center cartridge.
Old May 30, 2010 | 08:28 PM
rsxiness03's Avatar
soo now that we know the restrictor is included i shouldnt run into any problem feeding oikl to the turbo should i?
Old May 31, 2010 | 08:44 AM
Former Sponsor
Old May 31, 2010 | 09:15 AM
Irishflame27's Avatar
John Grant
do you suggest that when using -3 as well?
Funtimefrankie
Nov 24, 2013 10:47 AM
itlynstalyn
Dec 15, 2010 01:02 PM
NFRTurboTerror
Feb 16, 2007 08:16 PM
Spoolin
Oct 7, 2005 04:11 PM
flexer
May 11, 2005 11:25 AM
