Tap in Oil pan
Old May 2, 2005 | 09:40 PM
flexer's Avatar
Default Tap in Oil pan
1. So where is the best spot to tap a hole in the oil pan?
2. Where is a good place to get the adaptor that I should get welded onto the oilpan?
Thanks
J. R.
Old May 3, 2005 | 05:35 AM
Sideways's Avatar
What are you doing? Oil temp, oil return, oil cooler, or what? Location depends on what and clearances.
An oil return for a supercharger/turbo in the upper front left:
Old May 3, 2005 | 09:15 AM
flexer's Avatar
Sideways,
Yes it would be for a oil return. Could you maybe post the pick again so it would work, I would be interested to see it? Also where would I go about getting the correct fittings for a oil return?
Thanks
J. R.
Old May 9, 2005 | 11:55 AM
flexer's Avatar
Bump for pic
Old May 9, 2005 | 06:11 PM
fperra's Avatar
An oil return for what? Supercharger or turbo? If it's for a turbo, it all depends on how and where you mount the turbo. Let's get more specific here!
Old May 10, 2005 | 11:06 AM
flexer's Avatar
Sorry bout that.
Where would the tap go if I was usuing a lovefab manifold, so ie. top mount turbo GT30R.
J. R.
Old May 11, 2005 | 09:18 AM
flexer's Avatar
bump
Old May 11, 2005 | 11:25 AM
Scorpion's Avatar
Take a look under the car and look for a spot on the pan that is open (enough room for fittings and oil line). As long as it's near the top of the pan and clears the everthing under the pan...(oil pump and crank). On Vortech SC they are tapped in the front of the engine which is where the one in the pic looks to be, which you could do but you would have to run the oil line around the side of the block and up to the mani.
Japmuscle
May 31, 2013 08:47 AM
seoul2k
Apr 26, 2011 04:40 PM
Mijae007
Apr 19, 2011 06:43 PM
ChefJ
Aug 5, 2010 01:46 PM
ex-eclipse
Jul 18, 2006 02:47 AM
