Help with Supercharger Install
Old May 19, 2014 | 04:51 PM
S2G4life's Avatar
That's what I'm thinking. This company is too legit to not have a reason for why they did it. I emailed Richard but he's on vacation. I would feel better just knowing the explanation.
Originally Posted by CoolGuy094
^Yeah but then you have to find somebody with the capability to broach a keyway on the ID of the OEM pulley. TTS trusts that the 181 ft-lbs will successfully hold the two pulleys together without any slip between the two. I think you should just trust their judgement and not worry about it. If machined correctly to have a snug fit I highly doubt you'll have an issue. And I bet if it does start slipping, that aluminum pulley will heat up and expand so it won't slip for long.
Old May 19, 2014 | 04:52 PM
S2G4life's Avatar
I'm having a hard time finding someone in Dallas to even do it. How would you get the pulley off without the old locking system ?
Originally Posted by 06S2k07Si
Just did mine without a keyway and it seems to be fine...time will tell...still installing...
Old May 19, 2014 | 05:00 PM
S2G4life's Avatar
FYI - that walbro 450 doesn't fit in fuel pump holder. Have to get creative. A few write ups exist on here. Inter cooler pages in instructions are useless since we went bigger setup. Had to hammer a bit down on sides to get bracket holding intercooler to fit. It's snug.
Old May 19, 2014 | 07:10 PM
CoolGuy094's Avatar
They make devices called pulley wrenches that use a belt or chain to wrap around the pulley with a handle on them. They rely on the belt/chain tension/friction against the pulley surface to keep the pulley still while you undo the crank bolt.
Old May 19, 2014 | 07:19 PM
S2G4life's Avatar
Good to know. Appreciate it.
Old May 19, 2014 | 07:46 PM
06S2k07Si's Avatar
The new kit has a pulley tool included for tightening.
Old May 26, 2014 | 12:00 PM
Jayboy83's Avatar
I have the tts sport kit currently running at 410bhp, i have no issues with the fitting of the crank pulley, im also using the walbro 255, others i know of have had close to 500bhp on the race setup with no issues of the pulley slipping. This kit has been around for a long time over here, its been upgraded over the years with many changes, the current version of this kit is so much better than the originals, many if not all weakness in bolts, pulleys etc have been identified and upgraded. Im currently on a slightly older setup, using a c38-81 and different pulleys/bearings, one day i may upgrade the pulleys/bearings to the latest setup. Probably once they start to wear out.
i would have trust in tts that there will be no issues, as far as im concerned its tried and tested.
Old May 26, 2014 | 12:45 PM
TTS Performance's Avatar
Former Sponsor
I've just done 2850 miles around Europe in 9 days with no issues. There was some seriously quick driving going on. My last day was over 700 miles with speeds over 160 mph at times. Also lots of tight Italian mountain passes with 100's of miles of tight bends cut and thrust driving. It was awesome. Check out the Euromeet 2014 on the international threads.
Old May 26, 2014 | 01:20 PM
RAIN H8R's Avatar
You wont need to worry about the pulley spinning. The tightness of the torque spec will keep it from spinning.
King motorsports had it done for me very quickly. Dropped it off and picked it up withing 2 hours.
Sent from my Samsung Galaxy S4
Old May 26, 2014 | 04:59 PM
S2G4life's Avatar
Appreciate everyone's input. I trust TTSs judgement, but I just wanted to hear what fellow s2kiers had to say. Finally found someone to machine pulley, should be done with install next weekend. I'm going to run Walbro 255 till I upgrade fuel pump wiring.
spectacle
Nov 22, 2018 01:27 PM
picco97
Nov 9, 2016 09:33 PM
Jack_in_the_Box
May 26, 2012 09:28 PM
macr88
Forced induction/Engine Management
Mar 2, 2010 08:55 AM
