Help with troubleshooting
Old Nov 21, 2019 | 02:52 PM
  #21
F1TwoThousand's Avatar
Great news, thanks for sharing and looking forward to another boosted S2K!
Old Nov 22, 2019 | 06:26 PM
  #22
JMoss@TorqueFactoryConsul's Avatar
Originally Posted by Jkumar
She lives!! Replaced the line and she fired right up. Thanks all for your help. Can't wait to get the supercharger back on line and experience its maximum potential.
Please note that fuel hose that is submerged in fuel is different that typical EFi hose.
The outer layer will softer when soaked in fuel and eventually rupture.
Good luck.
Old Dec 2, 2019 | 10:15 AM
  #23
Jkumar's Avatar
Good luck.
What kind of hose should I use? I definitely want to get the right stuff before buttoning everything back together. Thanks for pointing that out.
Old Dec 2, 2019 | 11:34 AM
  #24
https://www.gates.com/us/en/fluid-po...-000000-000012
Or
Submersible PTFE Fuel Tubing
Old Dec 2, 2019 | 12:02 PM
  #25
Jkumar's Avatar
Thank you! Just to confirm is it 3/8 or 5/16? I can’t remember which one I used and I can’t seem to confirm it after searching.
Old Dec 2, 2019 | 12:14 PM
  #26
The manufacturer of whichever pump you are using should have the spec for the pump outlet/discharge size.
S2k basket fitting is 5/16".
The rubber hose is more forgiving to size up or down slightly.
Old Dec 2, 2019 | 12:20 PM
  #27
Jkumar's Avatar
Thank you!
Old Dec 2, 2019 | 01:06 PM
  #28
noodels's Avatar
Old Mar 13, 2020 | 08:05 AM
  #29
Jkumar's Avatar
Reviving this from the dead. Was having problems with the supercharger pulley bolt loosening and backing out. I tightened it back up after using some red loctite and have subsequently lost the bolt somewhere on the road. Two questions:
1. How do I prevent this in the future?
2. Is this what I need or is there another alternative? https://vortechsuperchargers.com/pro...novi-1000-2000
Thanks for the help.
vinom
Sep 16, 2018 10:36 AM
windhund116
Jan 16, 2018 04:57 PM
jinn
Dec 26, 2017 02:33 AM
Legal Bill
Dec 13, 2017 06:34 AM
