Help w/ Turbo!
Old Sep 15, 2010 | 12:29 PM
Angerman's Avatar
Default Help w/ Turbo!
Currently I have....
IP S1 Street kit.
3" downpipe
Intercooler
Piping
Boost controller
3.5 MAP w/ UEGO built in
Manifold
Turbo
BOV
I THINK I need....
Turbo timer
Pod
Wideband 02
Boost gauge kit
Oil Return
Injectors (675cc)
Fuel pump
I think that's all I need. I have a Greddy E-manage Ultimate. Goals, 350-400whp DD. I was trying to buy the AEM gauges from someone in FS thread, but he told me I needed AEM EMS for them to work . So I keep getting told different things and I don't know WTF is going on and why F/I is so ****** confusing.
Will EMU work fine with AEM gauges? Preferably these gauges - https://www.s2ki.com/forums/index.ph...f=107&t=814226
Old Sep 15, 2010 | 12:39 PM
s2000442's Avatar
You need standalone guages for wideband and boost; serial guages can be programed via aem. You are compromising yourself with the ultimate. Aem or kpro would be better.
Old Sep 15, 2010 | 12:41 PM
amok's Avatar
no it will not work with the emanage ultimate.
those gauges are made to read/communicate with the AEM EMS.
Old Sep 15, 2010 | 02:41 PM
dc2-2-ap1's Avatar
blow off valves don't come is sizes. you are probably thinking wastegates (which is something you left off your list) a 38mm wastegate would be fine. not needed if your turbo is internally wastegated. you also forgot the oil feed line (-3 an).
standard aem gauges will work but not the serial
Old Sep 15, 2010 | 02:50 PM
teamvalorracing's Avatar
^bov's do come in sizes.
38mm is like a greddy type-s/r/rs/z, then you can get 40mm hks, or 50mm tial. and then the tial comes in different size springs that pertain to vac.
you dont need a turbo timer.
go K-pro if you dont mind buying a bunch of rsx sensors. go aem if you dont mind some of its quirks.
Old Sep 15, 2010 | 06:54 PM
Angerman's Avatar
I found out that I do have a BOV. And a wastegate.
So I guess I need to invest in a AEM series 2 and sell my EMU...? Or Kpro...
Old Sep 15, 2010 | 06:56 PM
CKit's Avatar
It's going to be really painful to try and assemble your own kit without a lot of firsthand knowledge.
Old Sep 15, 2010 | 07:07 PM
Angerman's Avatar
That's my problem. I don't know shit about this garbage and this is my first F/I kit. I know this....
How to install the downpipe, intercooler, manifold, and turbo itself.
Thats what I know. All this mechanical garbage that comes with owning a turbo I know jack shit about and its really starting to tick me off. Really, how is it THIS HARD to put together a turbo setup. I am really getting close to just buying a supercharger.
LOL @ my s2ki name, I guess it shows
Old Sep 15, 2010 | 07:26 PM
amok's Avatar
Since you're kit is based off Inline Pro, I would suggest you read through Scott's build.
https://www.s2ki.com/forums/index.php?showtopic=670166
it will give you some ideas on what parts are needed to complete the kit.
Old Sep 15, 2010 | 07:32 PM
ChefJ's Avatar
I just hope its not your daily. If its not just dive in. You will know when you need something when you need it. pipes couplers t bolt clamps. All of that small stuff will show itself eventually if you are missing it. Mounting the intercooler is always fun.
