Here we go again
The motor is assembled and sitting in the garage...trying to figure out my meth setup so I can get the intake mani on, and my turbo manifold as well as turbo choice.
Really no hurry, since it's basically winter already.
Originally Posted by 02s2knick,Nov 15 2010, 06:42 PM
but since its winter just means you will make higher numbers!
what pistons and rods did you decide to go with? is your crank knife edged?
CP 9:1
Carillo Rods
Originally Posted by 02s2knick,Nov 15 2010, 07:07 PM
oh and what did you go for on your rod bearing clearances? was it the same as your mains?
Nice! Will follow this build. Love the block, is this the regular AEBS sleeves or less water cooling?
Is there any numbers on block and girdle to help matching them? Guess you can't mix it up between engines? Seen it on other engines designed like this.
