Here we go again
Subscribed. Nice work. And my oil squirters are blocked off as well, and run a healthy 80 psi of oil pressure w/ oil cooler. Good luck with the build and look forward for the final results. Inspiration for me down the road :-)
Originally Posted by siadam,Nov 15 2010, 08:33 PM
Maybe a 6265?
Not sure..
Not sure..
Originally Posted by B5254T4,Nov 15 2010, 11:03 PM
Nice! Will follow this build. Love the block, is this the regular AEBS sleeves or less water cooling?
Is there any numbers on block and girdle to help matching them? Guess you can't mix it up between engines? Seen it on other engines designed like this.
The top of the sleeves, have a "girlde" so to speak, I'm not sure what you are referring too?
Didn't seem like there was much interest in the setup this time around, so I've neglected the pics/info.
Here is the last pic I took a week or so ago.
It's linked from my FB account, not sure if you all will be able to see it or not.
The block is all black now, except for the head.
Originally Posted by siadam,Nov 16 2010, 07:46 PM
Regular sleeved block, it's going to be a street motor, so I didn't opt for less water cooling.
I´ve seen these "married" to the block by numbers, same in our engines?
Sorry man, bad English....
Originally Posted by B5254T4,Nov 16 2010, 12:20 PM
No, I meant the lower main cap piece, we call it girdle over here. The piece bolted to the block to keep the crank in place.
Thanks all for the kind comments, I'll post up some more pictures as I come across them.
