herecomesboost build thread
Old Mar 23, 2016 | 09:51 AM
  #101
herecomesboost's Avatar
Originally Posted by riceball777
My cars been running great. Just bought some drag radials and i'm going to try to take it to the drag stip for the first time. Thanks for asking.
Hows the 2.4 built on the blue car coming along? I still have the rotating assembly from my old 2.4 build if you need it.
Sweet! What times are you shooting for? Not worried about the rear? I will let you know about the 2.4 parts; still on the stock 2.2 currently.
Originally Posted by s2kt3
Hey Kyle. Built the Subaru, rotated gtx3076 and all the other bells and whistles. HATED THE LAG..... literally couldn't do it. sold it shortly after.
NOW.
im in a 2001 Silverstone. Bought it bone stock with oem hard top purchased at Honda as an option back in 2001. Then ap2 swapped (engine and trans), kpro, sos stage 2 @ 9psi, id1000's, kwv3's, stoptech bbk, 17x9 all around. basically making it into a time attack slayer. no more high hp. costs too much, im done with dumping every penny into a hobby where you always loose money.
Your silver car looks nuts!!!!
what trans and diff are in that car ?
Thanks Lee! 8.8" rear but stock trans; thinking about picking up a v160 from a member in NY. Sounds like a fun car.
Old Mar 23, 2016 | 10:43 AM
  #102
Fuel level signal wire needs to be tapped/sent to the Racepack USM (C8 on the back of the cluster):
DataLink software needs to first READ the calibration (from the Racepack display once the USM has been plugged in. All 4 outputs from the USM will automatically show up in the DataLink software; chose the one you used for your input (I used number 1 for my fuel level sensor signal)), then configured with the following paramaters:
^These are just the initial voltage values (exact voltages will be determined when I actually fill up the tank; these are close enough to get started though)
Next, SEND the calibration to the Racepak display after changing which parameters you want displayed on the first page (you can name the params (Channel Tag Output) whatever you'd like):
Just waiting on the adapter from Racepak so that the dash can display output from the CAN (Haltech ECU) and the VNET (Racepak USM).
Old Mar 23, 2016 | 01:56 PM
  #103
riceball777's Avatar
That racepack cluster is so sick!! Wiring like like a nightmare though.
Old Mar 23, 2016 | 03:17 PM
  #104
Yeah! Just wish it could display more parameters per page. Wiring is...interesting haha. On the plus side, the VNet connectors can daisy chain.
Old Mar 24, 2016 | 06:27 AM
  #105
liquidgsr's Avatar
Looks awesome Kyle. Hopefully I can check it out this weekend.
Old Mar 24, 2016 | 07:50 AM
  #106
Thanks Nesar. Sure thing. Do you still need the crank pulley socket?
Old Mar 24, 2016 | 08:10 AM
  #107
liquidgsr's Avatar
Sorry I couldn't message you back, screen broke on my phone. No I grabbed my friends yesterday.
Old Mar 26, 2016 | 03:10 PM
  #108
No problem. We'll meet up one of these days haha
Was able to get the fuel sensor output to work on the Racepak.
My little helper
The adapter cable(s)
It works! Still need to adjust the voltages a bit; very close though
Old Mar 26, 2016 | 04:41 PM
  #109
baZurk's Avatar
looks sweet!
Old Mar 26, 2016 | 07:09 PM
  #110
Originally Posted by baZurk
looks sweet!
Thanks Matt.
Filled the tank and measured the voltage. 1.55v with a full tank. Scaled the aforementioned table accordingly. Empty should be close to 5v, but I will measure again as soon as the tank is empty. The output is VERY sensitive. At idle or on smooth roads, the reading is stable, but cornering/accelerating/etc (basically, any time the fuel is in motion), the gauge jumps around. Oh well, it works!
