herecomesboost build thread (part 2)
Old May 12, 2013 | 06:51 AM
  #391
herecomesboost's Avatar
Originally Posted by Phill24
Did u end up having to notch the bracket?
Didn't have to notch the bracket at all. I did take your advice though and test fit the driveshaft on the flange prior to installing the diff (just in case).
Originally Posted by s2kt3
Ya it's a slip yoke...... Should fit..... Dss sent me a custom shaft for my build and it was perfect.
Showing my newb status with regard to driveshafts, I suppose lol.
Old May 12, 2013 | 09:55 AM
  #392
Phill24's Avatar
kool im glad everything is working out i see fbm made the proper adjustments to the fitment..that why i like buying they're products.... when do u think u'll be finish with everything?
Old May 12, 2013 | 10:33 AM
  #393
Yeah. I support LJ/FBM whenever possible; his/their customer service is unmatched, in my opinion. May be a little while before the car is back on the road. I'm thinking of just making the switch to e85 (instead of running q16 24/7 like JoeyBaller™). If I decide to stick with the q16 route, I just need to order a new turbo/downpipe.
Old May 12, 2013 | 10:55 AM
  #394
Phill24's Avatar
my tuner was telling me about another fuel called c85 he said its more consistant than e85 being that when u pump the E85 u could be getting anywhere between e70 to e90 i was also debating making the switch back to 93 and doing a dual map setup for either c85 or e98
http://www.vpracingfuels.com/blogs/v...istent-tuning-
Old May 12, 2013 | 11:05 AM
  #395
miguel329's Avatar
Originally Posted by herecomesboost' timestamp='1368383597' post='22537344
[quote name='Phill24' timestamp='1368381350' post='22537291']
[/quote]
E85 is pretty consistent at both pumps around here. Just need to watch out when they change from summer blend to winter blend. Most of us store car then anyways.
Sent from my SPH-L710 using Tapatalk 2
Old May 16, 2013 | 04:35 PM
  #396
d-bo's Avatar
Originally Posted by Uncoolron' timestamp='1367807037' post='22521465
Oh. Sorry to hear about that then. When Billman did mine last he used 1" or 1-1/4" breaker bar called Big Bertha :-)
lol
Originally Posted by manny-s2000
What turbo are you going to run with.. Precision?
6266 (not sure the s362 will fit; Pang relayed that he hasn't tried to mock up a BW turbo on this manifold, so he can't say definitively either way)
im not sure why this stupid thing keeps quoting multiple posts but this is in regards to your manifold.
i am very happy with my Bullseye thus far. happy enough that ill never go back to precision or garrett lol. that being said, i wonder if we sent the turbo to pang if he would be able to make it fit?
my S256 is probably the largest that will fit on his T3 ELT manifold as the downpipe is pretty much touching my relocated heater hose, and the turbo is about 3/4 inch away from the Valve cover . i would love to have pangs twinscroll manifold in the future assuming i could stepup to a larger turbo such as the s362 or 66 and make some monster jam (my wallet says No right now lol)
also interested in how the cage works out. I would like to have one too. 8pt in a convertible is fine for 9.99 right? please correct me if i am wrong. if i am doing a cage i think it would be impossible for me to get into my car if i switched to a hardtop though Lol. I think a caged convertible would look meaner anyway
Old May 16, 2013 | 04:52 PM
  #397
Hey Eric. Thanks for the info. The 8pt + a hardtop should be good to 9.99 (depends on the track, I suppose). I'm likely going with another Precision turbo (6266 this time). I've never had issues with them.
Old May 16, 2013 | 04:58 PM
  #398
timg's Avatar
Originally Posted by d-bo
Originally Posted by herecomesboost' timestamp='1367881311' post='22523713
[quote name='manny-s2000' timestamp='1367849270' post='22522184']
[/quote]
Note that the S300 series will fit on the T4 divided manifold from Pang. I'm running a S300SX FMW on his manifold. I did send the turbo to him to check fitment and to have an elbow welded onto the compressor housing. The turbine housing and downpipe clear with a ton of room (at least with regard to hard parts- the turbine housing was almost touching my previously relocated fusebox).
Tim
Old May 16, 2013 | 06:04 PM
  #399
Tim
After looking at your configuration, I doubt I'd be able to fit the S300 series on my T3 ELT. Your flange angle is rotated drastically towards the passenger frame rail (compared to mine).
Old May 16, 2013 | 06:05 PM
  #400
d-bo's Avatar
good to know! maybe his t4 Manifold is positioned differently
