herecomesboost build thread (part 2)
Old May 20, 2013 | 06:13 PM
  #421
herecomesboost's Avatar
Originally Posted by d-bo
car is going to look awesome !
Thanks Eric.
Originally Posted by neeman77
Sweet, good purchase! Trust me that manifold makes serious power lol.
Thanks! I hope so.
Originally Posted by sata3000
Lol! Awesome. I'm excited for you Kyle.
Thanks Thomas. Still want to swap hoods? lol
Originally Posted by hatchbone
All I can say is don't judge my boxing skills when it shows up lol that dp is long,the turbo manifold is in a indistructable padded edlebrock box , make sure clean the peanut out the dp before install though.thanks again
lol Thanks for the warning
Originally Posted by Phill24
I have the same setup u will make 700 depending on the turbo...i made 706 with mine which i thought was impossible with a 35r
Because I'm no longer spatially limited, I'll likely go with a BW 300sx (likely the 62mm). 700 on a 35r is awesome!
Old May 21, 2013 | 04:52 AM
  #422
sata3000's Avatar
Kyle I still have you hood. I was waiting for your car to be mobile so its not sitting around the shop freshly painted. Really the best way for me would for you to drive to my shop in the s2k and do the swap here.. If that's possible.
Old May 21, 2013 | 05:51 AM
  #423
That works for me. It may be a little while though lol
Old May 21, 2013 | 03:19 PM
  #424
I decided to redo the breather lines (I wasn't happy with the first iteration). They're not touching the piping (despite how they look in the pics):
Cutting a bolt to plug the vtec solenoid pressure switch:
Installed:
Old May 21, 2013 | 03:29 PM
  #425
wy2slow_z's Avatar
am I crazy. or are you missing a stud? on purpose? Im thinking about upgrading to arp's soon.
ps. if your goal is 700 the 62 sounds about right.
Old May 21, 2013 | 03:40 PM
  #426
lol The old stud came out with the nut (good eyes!); the manifold is only held by a single stud/nut currently (this was just a mock up). I'll likely reuse the stock studs/nuts for the time being.
Old May 28, 2013 | 06:51 PM
  #427
New manifold, new pass side mount, remote terminals installed:
Heat tape on the vtec solenoid (wiring); oil pressure sensor/vtec oil pressure sensor(s) deleted:
Just realized that I never posted completed pics of the rear diff install:
Old May 28, 2013 | 07:07 PM
  #428
bobbyrandolph440's Avatar
I would put
Big washers over thos diff mounts I have seen them pull loose b4 I'm doing it cause I have same ones
Sent from my DROID RAZR using Tapatalk 2
Old May 28, 2013 | 07:22 PM
  #429
I'll pick some up; thanks for the suggestion, Bobby.
Old May 28, 2013 | 07:29 PM
  #430
NP but u will need longer bolts I pick it all up at my local ace for less then 7.00 I went with the good grade8 bolts tho
