herecomesboost build thread (part 2)
Old Sep 19, 2013 | 11:50 AM
  #681
liquidgsr's Avatar
I wonder if its possible to backwards tune going from straight e85 to flex.
Old Sep 19, 2013 | 12:11 PM
  #682
herecomesboost's Avatar
^You can. Just use your current fuel/timing/boost maps as a template for your 93 map (subtracting fuel, of course); that should provide a good starting point. Your Blend vs Ethanol % would have a slope that is mirror image of mine (ie. sloping downward instead of upward) if your 93 map is the 'flex map.'
Old Sep 19, 2013 | 12:34 PM
  #683
liquidgsr's Avatar
Cool, I don't know much about tuning and will also need to keep the boost low for the break in.
Old Sep 23, 2013 | 02:02 PM
  #684
New fuel pump arrived this afternoon. I'm picking up a set of FID2000's this week from a friend (tom153). I maxed the ID1k's @ ~16.5ish psi on E70. I hope to install the new pump/injectors later this week/weekend.
Old Sep 23, 2013 | 02:19 PM
  #685
baZurk's Avatar
Cool Let me know if those ID1000's need a new home haha.
Old Sep 23, 2013 | 03:22 PM
  #686
I'm sure Matt (Shue) can set it up for you Otherwise, I'd be happy to help.
They'll be for sale shortly if you're interested
Old Sep 23, 2013 | 04:23 PM
  #687
WootRWD's Avatar
The id2000 are LOUUUDD
Old Sep 23, 2013 | 04:28 PM
  #688
So I've heard. I'm still using the factory rail, so they should be slightly less noisy (the fuel pulse dampener helps to quiet the injectors a bit).
Old Sep 23, 2013 | 04:47 PM
  #689
riceball777's Avatar
Can u post some pics when u install the Walbro e85 400 pump. I want to see how your going to wire it up.
Old Sep 23, 2013 | 05:02 PM
  #690
S2K-F8's Avatar
Originally Posted by herecomesboost
So I've heard. I'm still using the factory rail, so they should be slightly less noisy (the fuel pulse damper helps to quiet the injectors a bit).
Can you elaborate on this?
Scott-
