herecomesboost build thread (part 2)
I currently make 442whp on 91 octane at 14psi. I should be making 600-650whp on on e85 with a lot more boost.
So if the flex fuel tune is setup correctly. I will never need to drain the tank of 91 octane when switching to e85 correct? I will never need to hook up the aem ems to a PC to change to the e85 map? The ems will automatically raise the boost and raise the timing and inturn raise the Hp depending on the percentage of ethanol in the tank. Is this correct?
So if the flex fuel tune is setup correctly. I will never need to drain the tank of 91 octane when switching to e85 correct? I will never to hook up the aem ems to a OC to change to the e85 map? The ems will automatically raise the boost and raise the timing and inturn raise the Hp depending on the percentage of ethanol in the tank. Is this correct?
Nice. I think I'm going to get this flex fuel sensor and do the same thing your doing. I just need to talk to my tuner too see if be has any expearance with this yet.
When Your gauge reads e 50. Do you feel like the car is a lot faster than your straight 93 octane tune? I would think with e50 you should have at least 50-100 more whp.
wonder why not on v1
